ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructPointSymbol Method / ConstructPointSymbol(CIMMarker) Method
ArcGIS.Core.CIM.CIMMarker
Example
    Constructs a point symbol from a marker.
    Syntax
    CIMPointSymbol ConstructPointSymbol(
       CIMMarker marker
    Overloads Function ConstructPointSymbol( _
       ByVal marker As CIMMarker _
    ) As CIMPointSymbol
    Parameters
    marker
    Return Value
    Example
    How to construct a point symbol from a marker
      CIMMarker marker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.GreenRGB, 8.0, SimpleMarkerStyle.Pushpin);
      CIMPointSymbol pointSymbolFromMarker = SymbolFactory.Instance.ConstructPointSymbol(marker);
    How to construct a point symbol from a file on disk
      //The following file formats can be used to create the marker: DAE, 3DS, FLT, EMF, JPG, PNG, BMP, GIF
      await QueuedTask.Run(() =>
        CIMMarker markerFromFile = SymbolFactory.Instance.ConstructMarkerFromFile(@"C:\Temp\fileName.dae");
        CIMPointSymbol pointSymbolFromFile = SymbolFactory.Instance.ConstructPointSymbol(markerFromFile);
    How to construct a point symbol from a in memory graphic
      //Create a stream for the image
      //At 3.0 you need https://www.nuget.org/packages/Microsoft.Windows.Compatibility
      //System.Drawing
      System.Drawing.Image newImage = System.Drawing.Image.FromFile(@"C:\PathToImage\Image.png");
      var stream = new System.IO.MemoryStream();
      newImage.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
      stream.Position = 0;
      //Create marker using the stream
      CIMMarker markerFromStream = SymbolFactory.Instance.ConstructMarkerFromStream(stream);
      //Create the point symbol from the marker
      CIMPointSymbol pointSymbolFromStream = SymbolFactory.Instance.ConstructPointSymbol(markerFromStream);
    Modify a point symbol created from a character marker
      //create marker from the Font, char index,size,color
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Point Symbol from a font
    /// <summary>
    /// Create a point symbol from a character in a font file
    /// ![PointSymbolFont](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/point-marker.png)
    /// </summary>
      //creating the marker from the Font selected
      //Note: Run withing QueuedTask
      var cimMarker = SymbolFactory.Instance.ConstructMarker(47, "Wingdings 3", "Regular", 12);
      CIMPointSymbol fontPointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
      //To apply the symbol to a point feature layer
      //var renderer = pointLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = fontPointSymbol.MakeSymbolReference();
      //pointLayer.SetRenderer(renderer);
    Requirements
