ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructSolidFill Method
ArcGIS.Core.CIM.CIMColor
Example
    ConstructSolidFill Method (ISymbolFactory)
    Constructs a solid fill of specific color.
    Syntax
    CIMFill ConstructSolidFill(
       CIMColor color
    Function ConstructSolidFill( _
       ByVal color As CIMColor _
    ) As CIMFill
    Parameters
    color
    Return Value
    Example
    Modify a point symbol created from a character marker
      //create marker from the Font, char index,size,color
      await QueuedTask.Run(() =>
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Construct a Text Symbol With Options
        //using the default font
        var textSym1 = SymbolFactory.Instance.ConstructTextSymbol();
        var textSym2 = SymbolFactory.Instance.ConstructTextSymbol(
                           ColorFactory.Instance.BlueRGB, 14);
      //using a specific font
      var textSym3 = SymbolFactory.Instance.ConstructTextSymbol("Arial");
      var textSym4 = SymbolFactory.Instance.ConstructTextSymbol(
                        "Arial", "Narrow Bold");
      //or query available fonts to ensure the font is there
      var all_fonts = SymbolFactory.Instance.GetAvailableFonts();
      var font = all_fonts.FirstOrDefault(f => f.fontName == "Arial");
      if (!string.IsNullOrEmpty(font.fontName))
        var textSym5 = SymbolFactory.Instance.ConstructTextSymbol(font.fontName);
        //or with a font+style
        var textSym6 = SymbolFactory.Instance.ConstructTextSymbol(
                                        font.fontName, font.fontStyles.First());
      //overloads - font + color and size, etc
      var textSym7 = SymbolFactory.Instance.ConstructTextSymbol(
                      ColorFactory.Instance.BlueRGB, 14, "Times New Roman", "Italic");
      //custom symbol - black stroke, red fill
      var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
        SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB),
        SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1));
        var textSym8 = SymbolFactory.Instance.ConstructTextSymbol(
          poly_symbol, 14, "Georgia", "Bold");
    Custom fill and outline
    /// <summary>
    /// Creates a point symbol with custom fill and outline
    /// ![PointSymbolMarker](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/point-fill-outline.png)
    /// </summary>
      //Note: Run withing QueuedTask
      var circlePtCustomFileOutlineSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB, 6, SimpleMarkerStyle.Circle);
      //Modifying this point symbol with the attributes we want.
      //getting the marker that is used to render the symbol
      var marker = circlePtCustomFileOutlineSymbol.SymbolLayers[0] as CIMVectorMarker;
      //Getting the polygon symbol layers components in the marker
      var polySymbol = marker.MarkerGraphics[0].Symbol as CIMPolygonSymbol;
      //modifying the polygon's outline and width per requirements
      polySymbol.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid); //This is the outline
      polySymbol.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.GreenRGB); //This is the fill
      //To apply the symbol to a point feature layer
      //var renderer = pointLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = circlePtCustomFileOutlineSymbol.MakeSymbolReference();
      //pointLayer.SetRenderer(renderer);
    Requirements
