ArcGIS.Desktop.Mapping Namespace / BasicRasterLayer Class / CreateColorizer Method
The defined RasterColorizerDefinition.
    Creates a ArcGIS.Core.CIM.CIMRasterColorizer specifically for a BasicRasterLayer using a defined RasterColorizerDefinition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    colorizerDefinition
    Return Value
    Exceptions
    ExceptionDescription
    Cannot create colorizer for layer.
    Remarks
    Use CanCreateColorizer to determine if the colorizer is valid for the layer before creating it.
    Requirements
