Parameters
- map
- The map to be copied
Return Value
Map
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentNullException | The map is null. |
FrameworkApplication.Panes.CreateMapPaneAsync(mapCopy) to activate the newly copied map (if needed)Target Platforms: Windows 11 Home, Pro, Enterprise (64 bit)
