ArcGIS.Desktop.Mapping Namespace / StyleHelper Class / AddStyle Method
The current ArcGIS Pro project to which the style has to be added.
Name of a core ArcGIS Pro style or the full path to a style file (.stylx) on disk that has to be added to the current project.
Example
    AddStyle Method
    Adds the specified style to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static void AddStyle(
       Project project,
       string styleName
    Public Shared Sub AddStyle( _
       ByVal project As Project, _
       ByVal styleName As String _
    Parameters
    project
    styleName
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Remarks
    The path of style file to be added is case sensitive.
    Example
    How to add a style to project
      var project = Project.Current;
      await QueuedTask.Run(() =>
        //For ArcGIS Pro system styles, just pass in the name of the style to add to the project
        StyleHelper.AddStyle(project, "3D Vehicles");
        //For custom styles, pass in the full path to the style file on disk
        string customStyleToAdd = @"C:\Temp\CustomStyle.stylx";
        StyleHelper.AddStyle(project, customStyleToAdd);
    How to determine if a style can be upgraded
      //Add the style to the current project
      string stylePath = @"C:\MyStyles\OldStyle.stylx";
      await QueuedTask.Run(() => StyleHelper.AddStyle(project, stylePath));
      StyleProjectItem styleToUpgrade = Project.Current.GetItems<StyleProjectItem>().First(x => x.Path == stylePath);
      //returns true if style can be upgraded
      bool canUpgrade = styleToUpgrade.CanUpgrade;
    How to determine if a style is read-only
      string stylePath = @"C:\MyStyles\MyStyle.stylx";
      StyleProjectItem styleToCheck = Project.Current.GetItems<StyleProjectItem>().First(x => x.Path == stylePath);
      //returns true if style is read-only
      bool isReadOnly = styleToCheck.IsReadOnly;
    How to determine if a style is current
      //returns true if style matches the current Pro version
      bool isCurrent = styleToCheck.IsCurrent;
    How to upgrade a style
      bool success = false;
      //Verify that style can be upgraded
      if (styleToUpgrade.CanUpgrade)
        success = await QueuedTask.Run(() => StyleHelper.UpgradeStyle(styleToUpgrade));
    Requirements
