ArcGIS.Desktop.Core Namespace / Project Class
Members Example
    Project Class
    Represents an ArcGIS Pro project
    Object Model
    Project ClassProject ClassItem ClassIProjectWindow InterfaceIProjectWindow InterfaceCreateProjectSettings ClassItem ClassTimeInstant Class
    Syntax
    Remarks
    An ArcGIS Pro project must be created or opened before you can start to use the application
    Example
    Workflow to open an ArcGIS Pro project
      projectPath = @"https://<userName>.<domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
      string docVer = string.Empty;
      // A portal project path looks like this:
      //@"https://<ServerName>.<Domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
      //A local project path looks like this:
      //@"C:\Users\<UserName>\Documents\ArcGIS\Projects\MyProject\MyProject.aprx";
      //Check if the project can be opened
      if (Project.CanOpen(projectPath, out docVer))
        //Open the project
        Project.OpenAsync(projectPath);
      else //The project cannot be opened
        //One possible reason: If the project is a portal project, the active portal must match the portal of the project
        //Check if this is a portal project
        bool isPortalProject = Uri.TryCreate(projectPath, UriKind.Absolute, out Uri uriResult)
             && (uriResult.Scheme == Uri.UriSchemeHttp || uriResult.Scheme == Uri.UriSchemeHttps);
        if (isPortalProject)
          //Parse the project path to get the portal
          var uri = new Uri(projectPath);
          var portalUrlOfProjectToOpen = $"{uri.Scheme}://{uri.Host}/portal/";
          //Get the current active portal
          var activePortal = ArcGISPortalManager.Current.GetActivePortal();
          //Compare to see if the active Portal is the same as the portal of the project
          bool isSamePortal = activePortal != null && activePortal.PortalUri.ToString() == portalUrlOfProjectToOpen;
          if (!isSamePortal) //not the same.
            //Set new active portal to be the portal of the project
            //Find the portal to sign in with using its Uri...
            var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(portalUrlOfProjectToOpen, UriKind.Absolute));
            // Note: Needs QueuedTask to run
              if (!projectPortal.IsSignedOn())
                //Calling "SignIn" will trigger the OAuth popup if your credentials are
                //not cached (eg from a previous sign in in the session)
                if (projectPortal.SignIn().success)
                  //Set this portal as my active portal
                  ArcGISPortalManager.Current.SetActivePortal(projectPortal);
                  return;
            //Now try opening the project again
            else
              System.Diagnostics.Debug.WriteLine("The project cannot be opened.");
          else //The portals are the same. So the problem could be something else - permissions, portal is down?
        else //Project is on disk and cannot be opened.
    Determine if the project is a portal project from a project's path
      projectPath = Project.Current.Url;
        System.Diagnostics.Debug.WriteLine("This is a portal project");
      else
        System.Diagnostics.Debug.WriteLine("This is not a portal project");
      // Use isPortalProject;
    Determine if the project is a portal project from a project object
      var isPortalProject = Project.Current.IsPortalProject;
    Get the portal from a portal project's path
      //Check if the project is a portal project
        var fullUri = $"{uri.Scheme}://{uri.Host}/portal/";
        System.Diagnostics.Debug.WriteLine($"The Url of the project is: {fullUri}");
        //Now get the ArcGISPortal object from the portal Uri
        var arcgisPortal = ArcGISPortalManager.Current.GetPortal(new Uri(fullUri, UriKind.Absolute));
        System.Diagnostics.Debug.WriteLine($"The portal of the project is: {arcgisPortal.PortalUri}");
        //Note: You can set the active portal to be the portal of the project. Refer to this snippet: [ArcGISPortalManager: Get a portal and Sign In, Set it Active](ProSnippets-sharing#arcgisportalmanager-get-a-portal-and-sign-in-set-it-active)
    Retrieve a project item from a portal and open it
      var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(@"https://<serverName>.<domain>.com/portal/", UriKind.Absolute));
      string owner = string.Empty;
        //Get the signed on user name
        owner = projectPortal.GetSignOnUsername();
      //Get the user content from the portal
      PortalUserContent userContent = projectPortal.GetUserContentAsync(owner).Result;
      //Get the first portal project item
      var firstPortalProject = userContent.PortalItems.FirstOrDefault(pi => pi.PortalItemType == PortalItemType.ProProject);
      var portalProjectUri = firstPortalProject.ItemUri.ToString();
      //Check if project can be opened
      if (Project.CanOpen(portalProjectUri, out docVer))
        Project.OpenAsync(portalProjectUri);
      //Note: If Project.CanOpen returns false, the project cannot be opened. One reason could be
      // the active portal is not the same as the portal of the project. Refer to the snippet: [Workflow to open an ArcGIS Pro project](ProSnippets-sharing#workflow-to-open-an-arcgis-pro-project)
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Core.Project
    Requirements
