ArcGIS.Desktop.Mapping Namespace / StyleHelper Class / CreateStyle Method
The current ArcGIS Pro project to which the new style will be added.
The full path on disk of the new style file to be created.
Example
    CreateStyle Method
    Creates a new style file (.stylx) on disk and adds the style to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static void CreateStyle(
       Project project,
       string styleName
    Public Shared Sub CreateStyle( _
       ByVal project As Project, _
       ByVal styleName As String _
    Parameters
    project
    styleName
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Example
    How to create a new style
      //Full path for the new style file (.stylx) to be created
      string styleToCreate = @"C:\Temp\NewStyle.stylx";
      var project = Project.Current;
      await QueuedTask.Run(() => StyleHelper.CreateStyle(project, styleToCreate));
    Requirements
