Parameters
- project
- The current ArcGIS Pro project from which the style has to be removed.
- styleName
- Name of a core ArcGIS Pro style or the full path to a style file (.stylx) on disk that has to be removed from the current project.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run |
var project = Project.Current;
await QueuedTask.Run(() =>
//For ArcGIS Pro system styles, just pass in the name of the style to remove from the project
StyleHelper.RemoveStyle(project, "3D Vehicles");
//For custom styles, pass in the full path to the style file on disk
string customStyleToAdd = @"C:\Temp\CustomStyle.stylx";
StyleHelper.RemoveStyle(project, customStyleToAdd);
