ArcGIS.Desktop.Mapping Namespace / StyleHelper Class / SearchNorthArrows Method
The StyleProjectItem to search.
The search term.
Example
    Returns a collection of north arrow style items that satisfy the search criteria. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    styleProjectItem
    searchString
    The search term.
    Return Value
    A collection of NorthArrowStyleItem.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Example
    Create North Arrow From StyleItem 1
      //Create a north arrow using a style.
      //Search for a style project item by name
      StyleProjectItem arcgis2dStyles = Project.Current.GetItems<StyleProjectItem>()
                        .First(si => si.Name == "ArcGIS 2D");
      await QueuedTask.Run(() =>
      NorthArrowStyleItem naStyleItem = arcgis2dStyles.SearchNorthArrows(
                    "ArcGIS North 13").FirstOrDefault();
      //Reference the map frame and define the location
      MapFrame newFrame = layout.FindElement("New Map Frame") as MapFrame;
      Coordinate2D nArrow = new Coordinate2D(6, 2.5);
      //Construct the north arrow
      var naInfo = new NorthArrowInfo()
        MapFrameName = newFrame.Name,
        NorthArrowStyleItem = naStyleItem
      var newNorthArrow = ElementFactory.Instance.CreateMapSurroundElement(
                              layout, nArrow.ToMapPoint(), naInfo);
    Create North Arrow From StyleItem 2
      var project = Project.Current;
      //Build geometry
      Coordinate2D center = new Coordinate2D(7, 5.5);
      //Reference a North Arrow in a style
      StyleProjectItem stylePrjItm = project.GetItems<StyleProjectItem>()
                                     .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      NorthArrowStyleItem naStyleItm = stylePrjItm.SearchNorthArrows(
                                             "ArcGIS North 10")[0];
      //Reference MF, create north arrow and add to layout
      var mf = layout.FindElement("Map Frame") as MapFrame;
      var narrow_info = new NorthArrowInfo()
        MapFrameName = mf.Name,
        NorthArrowStyleItem = naStyleItm
      var arrowElm = (NorthArrow)ElementFactory.Instance.CreateMapSurroundElement(
        layout, center.ToMapPoint(), narrow_info) as NorthArrow;
      arrowElm.SetName("New North Arrow");
      arrowElm.SetHeight(1.75);
      arrowElm.SetX(7);
      arrowElm.SetY(6);
    How to search for north arrows in a style
      //Search for north arrows
      //Note: styleProjectItem was created above in the variable initialization section
      await QueuedTask.Run(() => styleProjectItem.SearchNorthArrows("searchString"));
    Requirements
