Public NotInheritable Class StyleProjectItem Inherits ArcGIS.Desktop.Internal.Core.ProjectItem Implements ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged, System.IComparable(Of StyleProjectItem), System.IDisposable
public sealed class StyleProjectItem : ArcGIS.Desktop.Internal.Core.ProjectItem, ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged, System.IComparable<StyleProjectItem>, System.IDisposable
IEnumerable<StyleProjectItem> newStyleItemsContainer = null;
newStyleItemsContainer = Project.Current.GetItems<StyleProjectItem>();
foreach (var styleItem in newStyleItemsContainer)
//Do Something with the style.
var container = Project.Current.GetItems<StyleProjectItem>();
// example: projectStyleName = "ArcGIS 3D";
StyleProjectItem testStyle = container.FirstOrDefault(style => style.Name == projectStyleName);
StyleItem cone = null;
if (testStyle != null)
// example: symbolName = "Cone_Volume_3";
cone = testStyle.LookupItem(StyleItemType.PointSymbol, symbolName);
// Use (testStyle, cone);
// Note: Needs QueuedTask to run
var containerStyle = Project.Current.GetProjectItemContainer("Style");
var fav_style_item = containerStyle.GetItems().OfType<StyleProjectItem>().First(item => item.TypeID == "personal_style");
//GetItems searches project content
var map = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name == "Map1");
var layout = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(m => m.Name == "Layout1");
var folders = Project.Current.GetItems<FolderConnectionProjectItem>();
var style = Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 3D");
//Find item uses a catalog path. The path can be to a file or dataset
var fcPath = @"C:\Pro\CommunitySampleData\Interacting with Maps\Interacting with Maps.gdb\Crimes";
var pdfPath = @"C:\Temp\Layout1.pdf";
var imgPath = @"C:\Temp\AddinDesktop16.png";
var fc = Project.Current.FindItem(fcPath);
var pdf = Project.Current.FindItem(pdfPath);
var img = Project.Current.FindItem(imgPath);
//Note: Must be on QueuedTask.Run
//Build geometry
List<Coordinate2D> plCoords = new List<Coordinate2D>();
plCoords.Add(new Coordinate2D(1, 8.5));
plCoords.Add(new Coordinate2D(1.66, 9));
plCoords.Add(new Coordinate2D(2.33, 8.1));
plCoords.Add(new Coordinate2D(3, 8.5));
Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
//Reference a line symbol in a style
var ProjectStyles = Project.Current.GetItems<StyleProjectItem>();
StyleProjectItem style = ProjectStyles.First(x => x.Name == "ArcGIS 2D");
var symStyle = style.SearchSymbols(StyleItemType.LineSymbol, "Line with 2 Markers")[0];
CIMLineSymbol lineSym = symStyle.Symbol as CIMLineSymbol;
lineSym.SetSize(20);
//Set symbology, create and add element to layout
//CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
ElementFactory.Instance.CreateGraphicElement(
layout, linePl, lineSym, "New Line");
//Note: Must be on QueuedTask.Run(() => { ...
//Build geometry
Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
//Reference a point symbol in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
StyleItemType.PointSymbol, "City Hall")[0];
CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
pointSym.SetSize(50);
var elemInfo = new ElementInfo()
CustomProperties = new List<CIMStringMap>() {
new CIMStringMap() { Key = "Key1", Value = "Value1"},
new CIMStringMap() { Key = "Key2", Value = "Value2"}
Anchor = Anchor.TopRightCorner,
Rotation = 45.0
var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
coord2D.ToMapPoint(), pointSym);
layout, graphic, "New Point", true, elemInfo);
//Create a simple 2D point graphic and apply an existing point style item as the symbology.
//Build 2D point geometry
//(optionally) Reference a point symbol in a style
StyleProjectItem ptStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
SymbolStyleItem ptSymStyleItm = ptStylePrjItm.SearchSymbols(
CIMPointSymbol pointSym = ptSymStyleItm.Symbol as CIMPointSymbol;
//An alternative simple symbol is also commented out below.
//This would eliminate the four optional lines of code above that
//reference a style.
//CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
// ColorFactory.Instance.RedRGB, 25.0, SimpleMarkerStyle.Star);
GraphicElement ptElm = ElementFactory.Instance.CreateGraphicElement(
layout, coord2D.ToMapPoint(), pointSym);
ptElm.SetName("New Point");
//Create a simple 2D line graphic and apply an existing line
//style item as the symbology.
//Build 2d line geometry
//(optionally) Reference a line symbol in a style
StyleProjectItem lnStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
SymbolStyleItem lnSymStyleItm = lnStylePrjItm.SearchSymbols(
CIMLineSymbol lineSym = lnSymStyleItm.Symbol as CIMLineSymbol;
// ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
GraphicElement lineElm = ElementFactory.Instance.CreateGraphicElement(
layout, linePl, lineSym);
lineElm.SetName("New Line");
//Create a simple 2D rectangle graphic and apply simple fill and
//outline symbols.
//Build 2D envelope geometry
Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
layout, rec_env, polySym, "New Rectangle");
//Or use Predefined shape
GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
layout, PredefinedShape.Rectangle, rec_env, polySym,
"New Rectangle2");
//Create a scale bar using a style.
//Search for a style project item by name
StyleProjectItem arcgis_2dStyle = Project.Current.GetItems<StyleProjectItem>()
.First(si => si.Name == "ArcGIS 2D");
//Reference the specific scale bar by name
ScaleBarStyleItem scaleBarItem = arcgis_2dStyle.SearchScaleBars(
"Double Alternating Scale Bar").FirstOrDefault();
//Reference the map frame and define the location
MapFrame myMapFrame = layout.FindElement("Map Frame") as MapFrame;
Coordinate2D coord2D = new Coordinate2D(10.0, 7.0);
//Construct the scale bar
var sbarInfo = new ScaleBarInfo()
MapFrameName = myMapFrame.Name,
ScaleBarStyleItem = scaleBarItem
ElementFactory.Instance.CreateMapSurroundElement(
layout, coord2D.ToMapPoint(), sbarInfo);
//Create a north arrow using a style.
StyleProjectItem arcgis2dStyles = Project.Current.GetItems<StyleProjectItem>()
//Construct on the worker thread
NorthArrowStyleItem naStyleItem = arcgis2dStyles.SearchNorthArrows(
"ArcGIS North 13").FirstOrDefault();
MapFrame newFrame = layout.FindElement("New Map Frame") as MapFrame;
Coordinate2D nArrow = new Coordinate2D(6, 2.5);
//Construct the north arrow
var naInfo = new NorthArrowInfo()
MapFrameName = newFrame.Name,
NorthArrowStyleItem = naStyleItem
var newNorthArrow = ElementFactory.Instance.CreateMapSurroundElement(
layout, nArrow.ToMapPoint(), naInfo);
//Build geometry
Coordinate2D ll = new Coordinate2D(5.0, 6);
Coordinate2D ur = new Coordinate2D(6.0, 7);
Envelope sbEnv = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
//Reference a Scale Bar in a style
ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
"Alternating Scale Bar 1")[0];
//ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
// "Double Alternating Scale Bar 1")[0];
// "Hollow Scale Bar 1")[0];
//Create Scale Bar
ScaleBarInfo sbInfo = new ScaleBarInfo()
MapFrameName = mapFrame.Name,
var sbElm = ElementFactory.Instance.CreateMapSurroundElement(
layout, sbEnv, sbInfo) as ScaleBar;
//Build geometry
Coordinate2D ll = new Coordinate2D(5.0, 8);
Coordinate2D ur = new Coordinate2D(6.0, 9);
"Scale Line 1")[0];
// "Stepped Scale Line")[0];
// "Scale Line 2")[0];
//Create Scale Bar
ScaleBarStyleItem = sbStyleItm
layout, sbEnv, sbInfo, "ScaleBar Line") as ScaleBar;
//Get all styles in the project
//Get a specific style in the project by name
StyleProjectItem styleFound = ProjectStyles.First(x => x.Name == "NameOfTheStyle");
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Core.Item
ArcGIS.Desktop.Mapping.StyleProjectItem
