Parameters
- symbol
- ArcGIS.Core.CIM.CIMSymbol
- size
- System.Double
//Note: Must be on QueuedTask.Run
//Build geometry
List<Coordinate2D> plCoords = new List<Coordinate2D>();
plCoords.Add(new Coordinate2D(1, 8.5));
plCoords.Add(new Coordinate2D(1.66, 9));
plCoords.Add(new Coordinate2D(2.33, 8.1));
plCoords.Add(new Coordinate2D(3, 8.5));
Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
//Reference a line symbol in a style
var ProjectStyles = Project.Current.GetItems<StyleProjectItem>();
StyleProjectItem style = ProjectStyles.First(x => x.Name == "ArcGIS 2D");
var symStyle = style.SearchSymbols(StyleItemType.LineSymbol, "Line with 2 Markers")[0];
CIMLineSymbol lineSym = symStyle.Symbol as CIMLineSymbol;
lineSym.SetSize(20);
//Set symbology, create and add element to layout
//CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
ElementFactory.Instance.CreateGraphicElement(
layout, linePl, lineSym, "New Line");
//Note: Must be on QueuedTask.Run(() => { ...
//Build geometry
Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
//Reference a point symbol in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
StyleItemType.PointSymbol, "City Hall")[0];
CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
pointSym.SetSize(50);
var elemInfo = new ElementInfo()
CustomProperties = new List<CIMStringMap>() {
new CIMStringMap() { Key = "Key1", Value = "Value1"},
new CIMStringMap() { Key = "Key2", Value = "Value2"}
Anchor = Anchor.TopRightCorner,
Rotation = 45.0
var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
coord2D.ToMapPoint(), pointSym);
layout, graphic, "New Point", true, elemInfo);
//Create a simple 2D point graphic and apply an existing point style item as the symbology.
//Build 2D point geometry
//(optionally) Reference a point symbol in a style
StyleProjectItem ptStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
SymbolStyleItem ptSymStyleItm = ptStylePrjItm.SearchSymbols(
CIMPointSymbol pointSym = ptSymStyleItm.Symbol as CIMPointSymbol;
//An alternative simple symbol is also commented out below.
//This would eliminate the four optional lines of code above that
//reference a style.
//CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
// ColorFactory.Instance.RedRGB, 25.0, SimpleMarkerStyle.Star);
GraphicElement ptElm = ElementFactory.Instance.CreateGraphicElement(
layout, coord2D.ToMapPoint(), pointSym);
ptElm.SetName("New Point");
//Create a simple 2D line graphic and apply an existing line
//style item as the symbology.
//Build 2d line geometry
//(optionally) Reference a line symbol in a style
StyleProjectItem lnStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
SymbolStyleItem lnSymStyleItm = lnStylePrjItm.SearchSymbols(
CIMLineSymbol lineSym = lnSymStyleItm.Symbol as CIMLineSymbol;
// ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
GraphicElement lineElm = ElementFactory.Instance.CreateGraphicElement(
layout, linePl, lineSym);
lineElm.SetName("New Line");
