ArcGIS.Desktop.Mapping Namespace / TOCActiveMapViewProviderPane Class / OnActivate Method
True if this pane is being made the active pane, otherwise false
    OnActivate Method (TOCActiveMapViewProviderPane)
    Called when the pane is activated (receives focus - active is true) or deactivated (loses focus - active is false).
    Syntax
    protected override void OnActivate(
       bool active
    Protected Overrides Sub OnActivate( _
       ByVal active As Boolean _
    Parameters
    active
    Requirements
