ArcGIS.Desktop.Mapping Namespace / TOCActiveMapViewProviderPane Class
Members
    Derive from TOCActiveMapViewProviderPane to continue to show the TOC of an associated MapView when your (derived) pane is activated. The MapView with the relevant TOC should be set in your Initialize override via the SetMapUri instance method.
    Object Model
    TOCActiveMapViewProviderPane ClassMapView ClassOperationManager ClassState ClassCIMView Class
    Syntax
    Remarks
    Typically, consumers will derive from TOCMapPaneProviderPane instead which provides full impersonation of a MapPane and its associated MapView.
    If you do use TOCActiveMapViewProviderPane then your derived class is responsible for handling any enabled state change, visibility change, etc. relevant to the MapView, whose TOC you are showing, being closed
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Framework.Contracts.PlugIn
             ArcGIS.Desktop.Framework.Contracts.PaneBase
                   ArcGIS.Desktop.Core.ViewStatePane
                      ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane
                         ArcGIS.Desktop.Mapping.TOCMapPaneProviderPane
    Requirements
