ArcGIS.Desktop.TaskAssistant Namespace / TaskProjectItem Class / TaskItemGuid Property
Example
    TaskItemGuid Property (TaskProjectItem)
    Gets the unique guid of the task item.
    Syntax
    public Guid TaskItemGuid {get;}
    Public ReadOnly Property TaskItemGuid As Guid
    Example
    Open a Project Task Item
      // get the first project task item
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
      // if there isn't a project task item, return
      if (taskItem == null)
        return;
      try
        // Open it
        //At 2.x -
        //System.Guid guid = await TaskAssistantModule.OpenTaskItemAsync(taskItem.TaskItemGuid);
        var guid = await TaskAssistantFactory.Instance.OpenTaskItemAsync(taskItem.TaskItemGuid);
        // TODO - retain the guid returned for use with CloseTaskItemAsync
      catch (OpenTaskException e)
        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
    Close a Task Item
      // find the first project task item which is open
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault(t => t.IsOpen == true);
        return;
      if (taskItem.IsOpen)
        // close it
        // NOTE : The task item will also be removed from the project
        //At 2.x -
        //TaskAssistantModule.CloseTaskAsync(taskItem.TaskItemGuid);
        TaskAssistantFactory.Instance?.CloseTaskItemAsync(taskItem.TaskItemGuid);
    Export a Task Item
        return;
      try
        // export the task item to the c:\Temp folder
        string exportFolder = @"c:\temp";
        //At 2.x -
        //string fileName = await TaskAssistantModule.ExportTaskAsync(taskItem.TaskItemGuid, exportFolder);
        string fileName = await TaskAssistantFactory.Instance.ExportTaskItemAsync(taskItem.TaskItemGuid, exportFolder);
        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Task saved to " + fileName);
      catch (ExportTaskException e)
        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Error saving task " + e.Message);
    Get Task Information - from a TaskProjectItem
        return;
      string message = await QueuedTask.Run(async () =>
        bool isOpen = taskItem.IsOpen;
        Guid taskGuid = taskItem.TaskItemGuid;
        string msg = "";
        try
          TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
          msg = "Name : " + taskItemInfo.Name;
          msg += "\r\n" + "Description : " + taskItemInfo.Description;
          msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
          msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
          // iterate the tasks in the task item
          IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
          foreach (TaskInfo taskInfo in taskInfos)
            string name = taskInfo.Name;
            Guid guid = taskInfo.Guid;
            // do something
          // exception thrown if task file doesn't exist or has incorrect format
          msg = e.Message;
        catch (TaskFileVersionException e)
          // exception thrown if task file does not support returning task information
          msg = e.Message;
        return msg;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
    Requirements
