ArcGIS.Desktop.Mapping Namespace / BasicRasterLayer Class / CreateColorizerAsync Method
The defined RasterColorizerDefinition.
Example
    Syntax
    Parameters
    colorizerDefinition
    Return Value
    Example
    Create a new colorizer based on a default colorizer definition and apply it to the raster layer
      await QueuedTask.Run(async () =>
        // Check if the Stretch colorizer can be applied to the raster layer.
        if (rasterLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
          // Create a new Stretch Colorizer Definition using the default constructor.
          StretchColorizerDefinition stretchColorizerDef_default = new StretchColorizerDefinition();
          // Create a new Stretch colorizer using the colorizer definition created above.
          CIMRasterStretchColorizer newStretchColorizer_default =
            await rasterLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
          // Set the new colorizer on the raster layer.
          rasterLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the raster layer
      //Get a color ramp from a style
      var project = Project.Current;
      StyleProjectItem ArcGISColorsStyleItem =
            project.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS Colors");
        var colorRamps = ArcGISColorsStyleItem.SearchColorRamps("Heat Map 4 - Semitransparent");
        CIMColorRamp colorRampToUse = colorRampList[0].ColorRamp;
          // Create a new Stretch Colorizer Definition specifying parameters
          // for band index, stretch type, gamma and color ramp.
          StretchColorizerDefinition stretchColorizerDef_custom =
            new StretchColorizerDefinition(1, RasterStretchType.ESRI, 2, colorRamp);
          // Create a new stretch colorizer using the colorizer definition created above.
          CIMRasterStretchColorizer newStretchColorizer_custom =
            await rasterLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          rasterLayer.SetColorizer(newStretchColorizer_custom);
    Create a new colorizer based on a default colorizer definition and apply it to the mosaic layer
        // Get the image sub-layer from the mosaic layer.
        ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
        // Check if the Stretch colorizer can be applied to the image sub-layer.
        if (mosaicImageSubLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
            await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
          // Set the new colorizer on the image sub-layer.
          mosaicImageSubLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the mosaic layer
          // Create a new Stretch colorizer definition specifying parameters
            await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          mosaicImageSubLayer.SetColorizer(newStretchColorizer_custom);
    Create a new colorizer based on a default colorizer definition and apply it to the image service layer
        // Check if the Stretch colorizer can be applied to the image service layer.
        if (imageServiceLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
            await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
          // Set the new colorizer on the image service layer.
          imageServiceLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the image service layer
            await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          imageServiceLayer.SetColorizer(newStretchColorizer_custom);
    Requirements
