ArcGIS.Core.Data Namespace / Version Class / Alter Method
The VersionDescription that specifies what information needs to be altered in this version.
    Alter Method (Version)
    Changes this version's name, description and access permissions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    versionDescription
    Exceptions
    ExceptionDescription
    versionDescription is null.
    The VersionDescription.Name value in versionDescription is null or an empty string.
    The VersionDescription.AccessType value in versionDescription is invalid.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
