ArcGIS.Core.Data Namespace / Version Class
Properties Methods
    Version Class Members
    The following tables list the members exposed by Version.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method Changes this version's name, description and access permissions. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Changes this version's owner. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Physically connects to this version in the geodatabase. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Deletes this version. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets this version's access permission. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a list of all the available child versions. If this version has no children, an empty list is returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a list of all conflicts with the target version. If there are no conflicts, an empty list is returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the mapping between container conflicts and the corresponding set of content conflicts. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the date and time this version was created. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets this version's description. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the date and time this version was last modified. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Gets the name of this version. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets this version's parent version. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether conflicts exist in this version. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether the current connected user is the owner of this version. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Public Method Refreshes the version with the corresponding database state. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Extension Methods
     NameDescription
    Public Extension MethodPartial posts this version against a target version specified in partialPostOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension MethodPosts this version against a target version specified in postOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension MethodOverloaded.
    Public Extension Method Refreshes the version and layers in all maps that references this version. This method must be called on the MCT. Use QueuedTask.Run.
    Top
