ArcGIS.Core.Data Namespace / CoreDataExtensions Class / PostInEditOperation Method
The Version instance to validate.
If PostOptions.TargetVersion is not specified in postOptions, then the target version is the Default version.
    Posts this version against a target version specified in postOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub PostInEditOperation( _
       ByVal version As Version, _
       ByVal postOptions As PostOptions _
    public static void PostInEditOperation(
       Version version,
       PostOptions postOptions
    Parameters
    version
    postOptions
    Exceptions
    ExceptionDescription
    postOptions is null.
    This operation is not supported in client-server mode because the data store supports multi-branch versioning.
    A Selection object specified in PostOptions.PartialPostSelections is not from a feature service feature class.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.7 or higher.
