ArcGIS.Core.Data Namespace / Version Class / IsOwner Method
    IsOwner Method
    Gets a value indicating whether the current connected user is the owner of this version. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool IsOwner()
    Public Function IsOwner() As Boolean
    Return Value
    true if the current connected user is the owner of this version; otherwise, false.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
