ArcGIS.Core.Data Namespace / Version Class / GetName Method
Example
    GetName Method (Version)
    Gets the name of this version. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public override string GetName()
    Public Overrides NotOverridable Function GetName() As String
    Return Value
    The name of this version.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Working with Versions
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
        using (VersionManager versionManager = geodatabase.GetVersionManager())
          IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
          Version defaultVersion = versionManager.GetDefaultVersion();
          string testVersionName = versionNames.First(v => v.Contains("Test"));
          Version testVersion = versionManager.GetVersion(testVersionName);
          Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
          Geodatabase qaVersionGeodatabase = qaVersion.Connect();
          FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
          FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
    Requirements
