Return Value
This version's parent version if it has a parent; otherwise, null.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
Task ReconcileAndPostAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
// Get a reference to our version and our parent
if (geodatabase.IsVersioningSupported())
using (VersionManager versionManager = geodatabase.GetVersionManager())
using (Version currentVersion = versionManager.GetCurrentVersion())
using (Version parentVersion = currentVersion.GetParent())
// Create a ReconcileOptions object
ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
if (!reconcileResult.HasConflicts)
//No conflicts, perform the post
PostOptions postOptions = new PostOptions(parentVersion);
//var postOptions = new PostOptions(); for default version
postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
// Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
// currentVersion.Post(postOptions);
currentVersion.Reconcile(reconcileOptions, postOptions);
Task ReconcileAndPost2Async(Geodatabase geodatabase) => QueuedTask.Run(() =>
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions, postOptions);
if (reconcileResult.HasConflicts)
//TODO resolve conflicts
Task<Version> FindDefaultVersionAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
if (!geodatabase.IsVersioningSupported())
return null;
Version currentVersion = versionManager.GetCurrentVersion();
Version defaultVersion = GetDefaultVersion(currentVersion);
if (currentVersion != defaultVersion)
currentVersion.Dispose(); // If we are not pointing to default, we want to dispose this Version object
return defaultVersion;
// Check to see if the current version is default.
// Works with both branch and traditional versioning.
bool IsDefaultVersion(Version version)
Version parentVersion = version.GetParent();
if (parentVersion == null)
return true;
parentVersion.Dispose();
return false;
// Gets the default version.
// Note that this routine depends on IsDefaultVersion(), above.
Version GetDefaultVersion(Version version)
if (IsDefaultVersion(version))
return version;
Version parent = version.GetParent();
Version ancestor = GetDefaultVersion(parent);
if (parent != ancestor)
parent.Dispose(); //If the versioning tree is more than 2 deep, we want to dispose any intermediary versions
return ancestor;
