ArcGIS.Core.Data Namespace / Version Class / GetConflictSets Method
    Gets the mapping between container conflicts and the corresponding set of content conflicts. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Return Value
    The mapping of the conflict categories as a Dictionary of Guid-Conflicts pairs.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    This function is only supported for branch versioning services with a utility network that contains a telecom domain network.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
