public IReadOnlyList<Version> GetChildren()
Public Function GetChildren() As IReadOnlyList(Of Version)
Return Value
A list of all the available child versions. If this version has no children, an empty list is returned.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
using (VersionManager versionManager = geodatabase.GetVersionManager())
IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
Version defaultVersion = versionManager.GetDefaultVersion();
string testVersionName = versionNames.First(v => v.Contains("Test"));
Version testVersion = versionManager.GetVersion(testVersionName);
Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
Geodatabase qaVersionGeodatabase = qaVersion.Connect();
FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
