ArcGIS.Core.Data Namespace / VersionManager Class / CreateVersion Method / CreateVersion(VersionDescription,Version) Method
The VersionDescription that specifies what the version should look like.
The parent Version under which the new version is created.
    Creates a new Version as a child of parent. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateVersion( _
       ByVal versionDescription As VersionDescription, _
       ByVal parent As Version _
    ) As Version
    Parameters
    versionDescription
    parent
    Exceptions
    ExceptionDescription
    versionDescription or parent is null.
    The VersionDescription.Name value in versionDescription is null or an empty string.
    The VersionDescription.AccessType value in versionDescription is invalid.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
