ArcGIS.Desktop.Mapping Namespace / MapViewOverlayControl Class
    MapViewOverlayControl Class Properties
    For a list of all members of this type, see MapViewOverlayControl members.
    Public Properties
     NameDescription
    Public Property Indicates a move handle should be attached to allow the control to be moved around over the map.
    Public Property Indicates that left and right resize handles should be attached to the control.
    Public Property Indicates that top and bottom resize handles should be attached to the control.
    Public Property The control to place over the MapView.
    Public Property Indicates a move handle should be usable behind any area of the control that is not hit test visible.
    Public Property The initial horizontal position of the control as a percent. Can be from 0 (left edge), to 1 (right edge).
    Public Property The initial vertical position of the control as a percent. Can be from 0 (top edge), to 1 (bottom edge).
    Public Property Indicates that only corner resize handles should be attached to the control when vertical and horizontal resize is allowed.
    Public Property The margin to maintain from the view border when moving the overlay.
    Public Property When the window is resized the distance from the edge is maintained relative to the top left or bottom right corner of the map.
    Top
