ArcGIS.Core.Data.Mapping Namespace / AnnotationFeatureClass Class / GetDefinition Method
Example
    GetDefinition Method (AnnotationFeatureClass)
    Gets the AnnotationFeatureClassDefinition of this dataset.
    Syntax
    public new AnnotationFeatureClassDefinition GetDefinition()
    Public Shadows Function GetDefinition() As AnnotationFeatureClassDefinition
    Return Value
    Exceptions
    ExceptionDescription
    This dataset does not have a valid definition.
    A geodatabase-related exception has occurred.
    Example
    Creating a new Annotation Feature in an Annotation FeatureClass using a RowBuffer
      Task CreatingAnAnnotationFeatureAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
        using (AnnotationFeatureClass annotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("Annotation // feature // class // name"))
        using (AnnotationFeatureClassDefinition annotationFeatureClassDefinition = annotationFeatureClass.GetDefinition())
        using (RowBuffer rowBuffer = annotationFeatureClass.CreateRowBuffer())
        using (AnnotationFeature annotationFeature = annotationFeatureClass.CreateRow(rowBuffer))
          annotationFeature.SetAnnotationClassID(0);
          annotationFeature.SetStatus(AnnotationStatus.Placed);
          // Get the annotation labels from the label collection
          IReadOnlyList<CIMLabelClass> labelClasses =
            annotationFeatureClassDefinition.GetLabelClassCollection();
          // Setup the symbol reference with the symbol id and the text symbol
          CIMSymbolReference cimSymbolReference = new CIMSymbolReference();
          cimSymbolReference.Symbol = labelClasses[0].TextSymbol.Symbol;
          cimSymbolReference.SymbolName = labelClasses[0].TextSymbol.SymbolName;
          // Setup the text graphic
          CIMTextGraphic cimTextGraphic = new CIMTextGraphic();
          cimTextGraphic.Text = "Charlotte, North Carolina";
          cimTextGraphic.Shape = new MapPointBuilderEx(new Coordinate2D(-80.843, 35.234), SpatialReferences.WGS84)
            .ToGeometry();
          cimTextGraphic.Symbol = cimSymbolReference;
          // Set the symbol reference on the graphic and store
          annotationFeature.SetGraphic(cimTextGraphic);
          annotationFeature.Store();
    Creating an annotation feature class inside feature dataset
      Task CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDatasetAsync(
        // Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
        // Feature dataset name
        string featureDatasetName = "Places";
        // Annotation feature class name
        string annotationFeatureClassName = "CitiesAnnotation";
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Open existing annotation feature class name
        using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
          // Create Feature dataset description
          FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
          // Add the creation of the Places dataset to DDL task
          FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
          // Create an annotation feature class description using existing annotation feature class
          AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
              existingAnnotationFeatureClass.GetDefinition())
            IsAutoCreate = true,
            IsSymbolIDRequired = false,
            IsUpdatedOnShapeChange = true
          // Add the creation of the Cities annotation feature class inside Places feature dataset
          schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
            annotationFeatureClassDescription);
          // Execute the DDL
          bool success = schemaBuilder.Build();
          // Inspect error messages
          if (!success)
            IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
            //etc.
    Requirements
