Public NotInheritable Class AnnotationFeatureClassDefinition Inherits ArcGIS.Core.Data.FeatureClassDefinition Implements System.IDisposable
public sealed class AnnotationFeatureClassDefinition : ArcGIS.Core.Data.FeatureClassDefinition, System.IDisposable
// Creates a new annotation template for the specified annotation layer. await QueuedTask.Run(() => { Inspector insp = null; // get the anno feature class var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass; // get the feature class CIM definition which contains the labels, symbols var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition; var labels = cimDefinition.GetLabelClassCollection(); var symbols = cimDefinition.GetSymbolCollection(); // make sure there are labels, symbols if (labels.Count == 0 || symbols.Count == 0) return; // find the label class required // typically you would use a subtype name or some other characteristic // in this case lets just use the first one var label = labels[0]; // each label has a textSymbol // the symbolName *should* be the symbolID to be used var symbolName = label.TextSymbol.SymbolName; int symbolID = -1; if (!int.TryParse(symbolName, out symbolID)) { // int.TryParse fails - attempt to find the symbolName in the symbol collection foreach (var symbol in symbols) { if (symbol.Name == symbolName) { symbolID = symbol.ID; break; } } } // no symbol? if (symbolID == -1) return; // load the schema insp = new Inspector(); insp.LoadSchema(annotationLayer); // ok to assign these fields using the inspector[fieldName] methodology // these fields are guaranteed to exist in the annotation schema insp["AnnotationClassID"] = label.ID; insp["SymbolID"] = symbolID; // set up some additional annotation properties AnnotationProperties annoProperties = insp.GetAnnotationProperties(); annoProperties.FontSize = 36; annoProperties.TextString = "My Annotation feature"; annoProperties.VerticalAlignment = VerticalAlignment.Top; annoProperties.HorizontalAlignment = HorizontalAlignment.Justify; insp.SetAnnotationProperties(annoProperties); var tags = new[] { "Annotation", "tag1", "tag2" }; // use daml-id rather than guid string defaultTool = "esri_editing_SketchStraightAnnoTool"; // tool filter is the tools to filter OUT var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" }; // create a new template var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter); });
// Must be called within QueuedTask.Run
void CreatingAnAnnotationFeature(Geodatabase geodatabase)
using (AnnotationFeatureClass annotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("Annotation // feature // class // name"))
using (AnnotationFeatureClassDefinition annotationFeatureClassDefinition = annotationFeatureClass.GetDefinition())
using (RowBuffer rowBuffer = annotationFeatureClass.CreateRowBuffer())
using (AnnotationFeature annotationFeature = annotationFeatureClass.CreateRow(rowBuffer))
annotationFeature.SetAnnotationClassID(0);
annotationFeature.SetStatus(AnnotationStatus.Placed);
// Get the annotation labels from the label collection
IReadOnlyList<CIMLabelClass> labelClasses =
annotationFeatureClassDefinition.GetLabelClassCollection();
// Setup the symbol reference with the symbol id and the text symbol
CIMSymbolReference cimSymbolReference = new CIMSymbolReference();
cimSymbolReference.Symbol = labelClasses[0].TextSymbol.Symbol;
cimSymbolReference.SymbolName = labelClasses[0].TextSymbol.SymbolName;
// Setup the text graphic
CIMTextGraphic cimTextGraphic = new CIMTextGraphic();
cimTextGraphic.Text = "Charlotte, North Carolina";
cimTextGraphic.Shape = new MapPointBuilderEx(new Coordinate2D(-80.843, 35.234), SpatialReferences.WGS84)
.ToGeometry();
cimTextGraphic.Symbol = cimSymbolReference;
// Set the symbol reference on the graphic and store
annotationFeature.SetGraphic(cimTextGraphic);
annotationFeature.Store();
void CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDataset(
// Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
// Feature dataset name
string featureDatasetName = "Places";
// Annotation feature class name
string annotationFeatureClassName = "CitiesAnnotation";
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Open existing annotation feature class name
using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
// Create Feature dataset description
FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
// Add the creation of the Places dataset to DDL task
FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
// Create an annotation feature class description using existing annotation feature class
AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
existingAnnotationFeatureClass.GetDefinition())
IsAutoCreate = true,
IsSymbolIDRequired = false,
IsUpdatedOnShapeChange = true
// Add the creation of the Cities annotation feature class inside Places feature dataset
schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
annotationFeatureClassDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
System.Object
ArcGIS.Core.CoreObjectsBase
ArcGIS.Core.Data.Definition
ArcGIS.Core.Data.TableDefinition
