ArcGIS.Core.Data.Mapping Namespace / AnnotationFeatureClassDefinition Class
Properties Methods
    AnnotationFeatureClassDefinition Class Members
    The following tables list the members exposed by AnnotationFeatureClassDefinition.
    Public Properties
     NameDescription
    Public Property Gets the dataset type. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method Gets the value of whether symbol overrides are allowed.
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the index position for a field by name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the alias name of the definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the name of the field containing the area of the shape. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public MethodGets a IReadOnlyList of the table's attribute rules. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public MethodGets a IReadOnlyList of the table's contingencies. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the name of the creation time field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the name of the creator field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the integer value representing the table's default subtype code. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the name of the edit time field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the name of the editor field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public MethodGets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that has been stored in the ArcGIS.Core.Data.FeatureClass. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public MethodGets the fields in the ArcGIS.Core.Data.Table. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the general placement properties of the annotation
    Public Method Gets the name of the GlobalID field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public MethodGets a IReadOnlyList of the table's ArcGIS.Core.Data.Index. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the collection of label classes for the annotation
    Public Method Gets the name of the field containing the length of the shape. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Method Gets the model name of the definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the name of the definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Definition)
    Public Method Gets the name of the ObjectID field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the value for the reference scale of the annotation. This method mush be called on the MCT. Use QueuedTask.Run
    Public Method Gets the unit that the reference scale is measured in.
    Public Method Gets the name of the field where the shape (geometry) is stored. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public MethodGets the ArcGIS.Core.Geometry.GeometryType for the ArcGIS.Core.Data.FeatureClass. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public MethodGets the ArcGIS.Core.Geometry.SpatialReference for the ArcGIS.Core.Data.FeatureClass. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public MethodGets the ArcGIS.Core.Data.SplitModel of the feature. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Method Gets the name of the field used to define subtypes. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public MethodGets a IReadOnlyList of the table's subtype codes. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method The symbol collection for the annotation.
    Public Method Gets the name of the ValidationStatus field. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the version of the annotation
    Public Method Gets a value indicating whether this table has a field containing GlobalIDs. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets a value indicating whether this feature class supports storing measure(M) information with its shapes. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Method Gets a value indicating whether this table has a field containing ObjectIDs. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets a value indicating whether this feature class has a spatial index. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Method Gets a value indicating whether this feature class supports storing vertical(Z) information with its shapes. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Method Gets whether annotation is to be automatically created when a feature is created.
    Public Method Gets a value indicating whether this feature class is COGO (Coordinate Geometry) enabled. (Inherited from ArcGIS.Core.Data.FeatureClassDefinition)
    Public Method Gets a value indicating whether editor tracking is enabled for the associated Table dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets the value of whether the annotation requires a symbol id.
    Public Method Gets a value indicating whether this table stores time in UTC or database time. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.TableDefinition)
    Public Method Gets whether the annotation updates when the feature's shape changes.
    Top
