ArcGIS.Core.Data.Mapping Namespace / AnnotationFeatureClassDefinition Class / GetLabelClassCollection Method
Example
    Gets the collection of label classes for the annotation
    Syntax
    Public Function GetLabelClassCollection() As IReadOnlyList(Of CIMLabelClass)
    public IReadOnlyList<CIMLabelClass> GetLabelClassCollection()
    Return Value
    An array of ArcGIS.Core.CIM.CIMLabelClass used to create the annotation.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Create Annotation Template
    // Creates a new annotation template for the specified annotation layer.
    await QueuedTask.Run(() =>
        Inspector insp = null;
        // get the anno feature class
        var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass;
        // get the feature class CIM definition which contains the labels, symbols
        var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition;
        var labels = cimDefinition.GetLabelClassCollection();
        var symbols = cimDefinition.GetSymbolCollection();
        // make sure there are labels, symbols
        if (labels.Count == 0 || symbols.Count == 0)
          return;
        // find the label class required
        //   typically you would use a subtype name or some other characteristic
        // in this case lets just use the first one
        var label = labels[0];
        // each label has a textSymbol
        // the symbolName *should* be the symbolID to be used
        var symbolName = label.TextSymbol.SymbolName;
        int symbolID = -1;
        if (!int.TryParse(symbolName, out symbolID))
          // int.TryParse fails - attempt to find the symbolName in the symbol collection
          foreach (var symbol in symbols)
            if (symbol.Name == symbolName)
              symbolID = symbol.ID;
              break;
        // no symbol?
        if (symbolID == -1)
          return;
        // load the schema
        insp = new Inspector();
        insp.LoadSchema(annotationLayer);
        // ok to assign these fields using the inspector[fieldName] methodology
        //   these fields are guaranteed to exist in the annotation schema
        insp["AnnotationClassID"] = label.ID;
        insp["SymbolID"] = symbolID;
        // set up some additional annotation properties
        AnnotationProperties annoProperties = insp.GetAnnotationProperties();
        annoProperties.FontSize = 36;
        annoProperties.TextString = "My Annotation feature";
        annoProperties.VerticalAlignment = VerticalAlignment.Top;
        annoProperties.HorizontalAlignment = HorizontalAlignment.Justify;
        insp.SetAnnotationProperties(annoProperties);
        var tags = new[] { "Annotation", "tag1", "tag2" };
        // use daml-id rather than guid
        string defaultTool = "esri_editing_SketchStraightAnnoTool";
        // tool filter is the tools to filter OUT
        var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" };
        // create a new template
        var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter);
    Creating a new Annotation Feature in an Annotation FeatureClass using a RowBuffer
      // Must be called within QueuedTask.Run
      void CreatingAnAnnotationFeature(Geodatabase geodatabase)
        using (AnnotationFeatureClass annotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("Annotation // feature // class // name"))
        using (AnnotationFeatureClassDefinition annotationFeatureClassDefinition = annotationFeatureClass.GetDefinition())
        using (RowBuffer rowBuffer = annotationFeatureClass.CreateRowBuffer())
        using (AnnotationFeature annotationFeature = annotationFeatureClass.CreateRow(rowBuffer))
          annotationFeature.SetAnnotationClassID(0);
          annotationFeature.SetStatus(AnnotationStatus.Placed);
          // Get the annotation labels from the label collection
          IReadOnlyList<CIMLabelClass> labelClasses =
            annotationFeatureClassDefinition.GetLabelClassCollection();
          // Setup the symbol reference with the symbol id and the text symbol
          CIMSymbolReference cimSymbolReference = new CIMSymbolReference();
          cimSymbolReference.Symbol = labelClasses[0].TextSymbol.Symbol;
          cimSymbolReference.SymbolName = labelClasses[0].TextSymbol.SymbolName;
          // Setup the text graphic
          CIMTextGraphic cimTextGraphic = new CIMTextGraphic();
          cimTextGraphic.Text = "Charlotte, North Carolina";
          cimTextGraphic.Shape = new MapPointBuilderEx(new Coordinate2D(-80.843, 35.234), SpatialReferences.WGS84)
            .ToGeometry();
          cimTextGraphic.Symbol = cimSymbolReference;
          // Set the symbol reference on the graphic and store
          annotationFeature.SetGraphic(cimTextGraphic);
          annotationFeature.Store();
    Requirements
