ArcGIS.Core.Data Namespace / TableDefinition Class / IsTimeInUTC Method
    IsTimeInUTC Method
    Gets a value indicating whether this table stores time in UTC or database time. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsTimeInUTC() As Boolean
    public bool IsTimeInUTC()
    Return Value
    true if this table stores time in UTC, false if in database time.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Remarks
    The official abbreviation for Coordinated Universal Time is UTC. If IsTimeInUTC returns true, time is stored in UTC; otherwise, time is stored in database time.
    Requirements
