public TerminalConfiguration GetTerminalConfiguration()
Public Function GetTerminalConfiguration() As TerminalConfiguration
// This routine demonstrates how to perform a trace and export the results as a JSON file
static void ExportUtilityNetworkTraceAsJSON(UtilityNetwork utilityNetwork)
using (TraceManager traceManager = utilityNetwork.GetTraceManager())
using (UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition())
using (NetworkSource deviceNetworkSource = GetNetworkSource(utilityNetworkDefinition, "GasDevice") as NetworkSource)
using (FeatureClass distributionDeviceFeatureClass = utilityNetwork.GetTable(deviceNetworkSource) as FeatureClass)
using (FeatureClassDefinition distributionDeviceDefinition = distributionDeviceFeatureClass.GetDefinition())
using (AssetGroup deviceAssetGroup = deviceNetworkSource.GetAssetGroup("Regulator"))
using (AssetType deviceAssetType = deviceAssetGroup.GetAssetType("Pressure Reducing"))
using (NetworkAttribute deviceStatusNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("DeviceStatus"))
using (NetworkAttribute accessibleNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Accessible"))
// Domain and tier information
DomainNetwork domainNetwork = utilityNetworkDefinition.GetDomainNetwork("Gas");
Tier pipeDistributionSystemTier = domainNetwork.GetTier("Pipe Distribution");
// Start elements
Element startingPoint1 = utilityNetwork.CreateElement(deviceAssetType, Guid.Parse("{28CF437E-950C-41B7-B839-8BC45570DE40}"));
Element startingPoint2 = utilityNetwork.CreateElement(deviceAssetType, Guid.Parse("{63C22828-7BC9-49ED-A14A-A596559B6CB3}"));
startingPoint1.Terminal = startingPoint1.AssetType.GetTerminalConfiguration().Terminals
.First(x => x.IsUpstreamTerminal);
startingPoint2.Terminal = startingPoint2.AssetType.GetTerminalConfiguration().Terminals
List<Element> startingPoints = [startingPoint1, startingPoint2];
List<Element> barriers = [];
// Set up trace filter: DeviceStatus = Open (1) AND Accessible = 1
NetworkAttributeComparison statusNetworkAttributeComparison = new NetworkAttributeComparison(deviceStatusNetworkAttribute, Operator.Equal, 1);
NetworkAttributeComparison networkAttributeComparison = new NetworkAttributeComparison(accessibleNetworkAttribute, Operator.Equal, 1);
// Set trace configuration
TraceConfiguration traceConfiguration = new TraceConfiguration
AllowIndeterminateFlow = true,
IgnoreBarriersAtStartingPoints = false,
IncludeBarriersWithResults = true,
IncludeContainers = true,
IncludeContent = true,
IncludeIsolatedFeatures = false,
IncludeUpToFirstSpatialContainer = false
traceConfiguration.Filter.Barriers = new And(statusNetworkAttributeComparison, networkAttributeComparison);
traceConfiguration.DomainNetwork = domainNetwork;
traceConfiguration.SourceTier = pipeDistributionSystemTier;
// Attribute fields of a network source
List<string> deviceFields = distributionDeviceDefinition.GetFields().Select(f => f.Name).ToList();
// Network attributes
List<string> networkattributeNames = new List<string>();
IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
foreach (NetworkAttribute networkAttribute in networkAttributes)
networkattributeNames.Add(networkAttribute.Name);
// Result Types
List<ResultType> resultTypeList = new List<ResultType>() { ResultType.Feature };
// Resutl Options
ResultOptions resultOptions = new ResultOptions()
IncludeGeometry = true,
NetworkAttributes = networkattributeNames,
ResultFields = new Dictionary<NetworkSource, List<string>>() { { deviceNetworkSource, deviceFields } }
// Trace Arguments
TraceArgument traceArgument = new TraceArgument(startingPoints)
Barriers = barriers,
Configuration = traceConfiguration,
ResultTypes = resultTypeList,
ResultOptions = resultOptions
ConnectedTracer connectedTracer = traceManager.GetTracer<ConnectedTracer>();
// Set export options
TraceExportOptions exportOptions = new TraceExportOptions()
ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
IncludeDomainDescriptions = true,
// Path to export JSON
string jsonPath = $"{Path.GetTempPath()}TraceResults.json";
Uri jsonUri = new Uri(jsonPath);
// Export
connectedTracer.Export(jsonUri, traceArgument, exportOptions);
string jsonAbsolutePath = HttpUtility.UrlDecode(jsonUri.AbsolutePath);
if (jsonUri.IsFile && File.Exists(jsonAbsolutePath))
// Work with the JSON results
NetworkSource GetNetworkSource(UtilityNetworkDefinition unDefinition, string name)
IReadOnlyList<NetworkSource> allSources = unDefinition.GetNetworkSources();
foreach (NetworkSource source in allSources)
if (name.Contains("Partitioned Sink"))
if (source.Name.Replace(" ", "").ToUpper().Contains(name.Replace(" ", "").ToUpper()) ||
.Contains(name.Replace("Partitioned Sink", "Part_Sink").Replace(" ", "").ToUpper()))
return source;
if (name.Contains("Hierarchical Sink"))
.Contains(name.Replace("Hierarchical Sink", "Hier_Sink").Replace(" ", "").ToUpper()))
return source;
if (source.Name.Replace(" ", "").ToUpper().Contains(name.Replace(" ", "").ToUpper()))
return source;
return null;
// This routine demonstrates how to fetch features and network attributes from a utility network during a trace
static void FetchFeaturesAndAttributes(UtilityNetwork utilityNetwork)
using (Geodatabase geodatabase = utilityNetwork.GetDatastore() as Geodatabase)
using (RelationshipClass valveInspectionRelationshipClass = geodatabase.OpenDataset<RelationshipClass>("GasDeviceToValveInspection"))
using (Table valveInspection = geodatabase.OpenDataset<Table>("ValveInspection"))
using (TableDefinition valveInspectionDefn = valveInspection.GetDefinition())
// Start elements
List<Element> startingPoints = new List<Element>() { startingPoint1, startingPoint2 };
List<Element> barriers = new List<Element>();
// Get the field names for the related records table (ValveInspection)
IReadOnlyList<Field> valveRelatedRecords = valveInspectionDefn.GetFields();
List<string> valveFieldNames = valveRelatedRecords.Select(f => f.Name).ToList();
// Result Types
List<ResultType> resultTypeList = new List<ResultType>() { ResultType.Feature, ResultType.RelatedRecord };
// Resutl Options
ResultFields = new Dictionary<NetworkSource, List<string>>() { { deviceNetworkSource, deviceFields } },
RelatedRecordFields = new Dictionary<RelationshipClass, List<string>>() { { valveInspectionRelationshipClass, valveFieldNames } }
// Trace Arguments
// Tracer
// Async trace result
IReadOnlyList<Result> traceResults =
connectedTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous);
// Iterate trace results
foreach (Result traceResult in traceResults)
if (traceResult is FeatureElementResult featureElementResult)
IReadOnlyList<FeatureElement> featureElements = featureElementResult.FeatureElements;
// Iterate through the feature elements
foreach (FeatureElement featureElement in featureElements)
// Get the field values specified in the `ResultOptions`
IReadOnlyList<TraceResultFieldValue> resultFieldValues = featureElement.ResultFieldValues;
foreach (TraceResultFieldValue fieldValue in resultFieldValues)
if (fieldValue.FieldType == FieldType.Geometry)
// Get the geometry of the feature
Geometry geometry = fieldValue.Value as Geometry;
// Get the Network attribute values specified in the `ResultOptions`
IReadOnlyList<TraceResultFieldValue> networkAttributeValues = featureElement.ResultNetworkAttributeValues;
if (traceResult is RelatedRecordResult relatedRecordResult)
IReadOnlyList<RelatedRecord> relatedRecords = relatedRecordResult.RelatedRecords;
// Iterate through the related records
foreach (RelatedRecord relatedRecord in relatedRecords)
IReadOnlyList<RelationshipClassValue> relationshipClassValues = relatedRecord.RelationshipClassValues;
foreach (RelationshipClassValue relationshipClassValue in relationshipClassValues)
// Access the IDs and name associated with this relationship class
var destinationId = relationshipClassValue.DestinationID;
var name = relationshipClassValue.Name;
var originId = relationshipClassValue.OriginID;
// Access the relationship values associated with this relationship class
IReadOnlyList<RelationshipValue> relationshipValues = relationshipClassValue.RelationshipValues;
foreach (RelationshipValue relationshipValue in relationshipValues)
// Geometry associated with this relationship value
Geometry geometry = relationshipValue.Geometry;
// Out fields associated with non attributed relationship class
IReadOnlyList<TraceResultFieldValue> outFields = relationshipValue.OutFields;
// Out fields associated with attributed relationship class
// IReadOnlyList<TraceResultFieldValue> relationshipOutFields = relationshipValue.RelationshipOutFields;
// Helper inline function
return source;
return source;
return source;
return null;
