ArcGIS.Core.Data.UtilityNetwork Namespace (ArcGIS.Core)
This namespace contains types used by the utility network.
Classes
| | Class | Description |
 | AssetGroup |
The AssetGroup class provides information about Asset Groups within the utility network. In the core geodatabase, they are implemented as subtypes.
 | AssetType |
Gets information about the definition of an Asset Type.
 | Association |
Represents a connectivity (spatial and non-spatial), containment, or structural attachment association.
 | AssociationFeature | Represents a connectivity, containment, or structural attachment association, including a ArcGIS.Core.Geometry.Geometry representing a connection between the two rows involved in the association. |
 | ConfigurationPath | The configuration path class details the set of flow paths between Terminals for a given device configuration. |
 | DomainNetwork | The DomainNetwork class is used to represent a domain network inside a utility network. A domain network typically represents an industry domain such as 'Electric Distribution', 'Gas', or 'Water.' DomainNetwork objects can be obtained by calling UtilityNetworkDefinition.GetDomainNetworks. |
 | Element |
Represents a row inside a utility network.
 | ExportOptions |
Represents a mechanism to perform an export operation.
 | NetworkAttribute | The NetworkAttribute class is used to represent a network attribute inside a utility network. Network attributes correspond to weights in the geometric network. NetworkAttribute objects can be obtained by calling UtilityNetworkDefinition.GetNetworkAttributes or UtilityNetworkDefinition.GetNetworkAttribute |
 | NetworkAttributeAssignment | Describes an assignment of a NetworkAttribute to a particular ArcGIS.Core.Data.Field of a NetworkSource. |
 | NetworkSource |
Represents a network source in a utility network.
 | Rule |
Represents a rule in the utility network. These define how features can be associated with each other through connectivity, containment, and attachment.
 | RuleElement |
Represents an element of a utility network rule. Each element represents one participant in an association.
 | Subnetwork |
Represents a subnetwork (circuit, zone) in a utility network
 | SubnetworkController |
Represents subnetwork controller.
 | SubnetworkExportOptions | Represents a mechanism to export a Subnetwork. |
 | SubnetworkManager |
The SubnetworkManager is a class that contains a collection of subnetwork management routines.
 | Terminal |
Represents a single terminal on a junction feature.
 | TerminalConfiguration | Represents a configuration of Terminal objects that are assigned to zero or more AssetTypes. |
 | TerminalPath | A value object that specifies a flow path between two Terminals. |
 | Tier |
Tiers demarcate a logical level within a network. E.g., in an electric distribution network, there may be Subtransmission, MediumVoltage and LowVoltage tiers.
 | TierGroup |
Tier groups provide an extra level of organization for tiers.
For example, a gas network may be divided into two tier groups - Transmission and Distribution.
Each of these tier groups would contain a set of tiers specific to that group. For example, Distribution Pressure and Distribution Isolation might be tiers within the
Distribution tier group.
 | TraverseAssociationsDescription | Represents a mechanism to return Association objects in a specified TraversalDirection. |
 | TraverseAssociationsResult | Represents a collection of Associations and the mapping between involved Elements and their field name-values from an associations traversal operation. |
 | UtilityNetwork |
Represents a utility network.
 | UtilityNetworkDefinition |
Represents the schema and properties of a utility network.
 | UtilityNetworkServerCapabilities | Represents the set of supported capabilities of a UtilityNetwork in a feature service connection. |
 | UtilityNetworkState |
Provides information about the current state of the utility network
 | ValidationResult | Provides information about the results of a call to UtilityNetwork.ValidateNetworkTopology. |
Enumerations
