ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkDefinition Class / GetDomainNetworks Method
    Gets an IReadOnlyList of DomainNetwork objects defined by this utility network. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDomainNetworks() As IReadOnlyList(Of DomainNetwork)
    public IReadOnlyList<DomainNetwork> GetDomainNetworks()
    Return Value
    An IReadOnlyList of DomainNetwork objects.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
