ArcGIS.Core.Data.UtilityNetwork Namespace / Element Class
Members Example
    Element Class
    Represents a row inside a utility network.
    Object Model
    Element ClassAssetGroup ClassAssetType ClassNetworkSource ClassTerminal Class
    Syntax
    Public Class Element
       Implements System.IEquatable(Of Element)
    public class Element : System.IEquatable<Element>
    Remarks
    The Element class is used to represent a row inside a utility network.
    • If the row represents a junction with terminals, Element can also specify a terminal.
    • If the row represents a line to be used as a tracing starting point or barrier, the percent along the edge can be specified to specify an exact location.
    Elements can be created using the CreateElement factory methods on the UtilityNetwork class and can be returned with trace results.
    Example
    Fetching a Row from an Element
      static Row FetchRowFromElement(UtilityNetwork utilityNetwork, Element element)
        // Get the table from the element
        using (Table unTable = utilityNetwork.GetTable(element.NetworkSource))
          // Create a query filter to fetch the appropriate row
          QueryFilter queryFilter = new QueryFilter()
            ObjectIDs = new List<long>() { element.ObjectID }
          // Fetch and return the row
          using (RowCursor rowCursor = unTable.Search(queryFilter))
            if (rowCursor.MoveNext())
              return rowCursor.Current;
            return null;
    Inheritance Hierarchy
    Requirements
