ArcGIS.Core.Data.UtilityNetwork Namespace / NetworkSource Class / GetAssetGroup Method
The name of the AssetGroup to return.
    Gets an AssetGroup object with the specified name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAssetGroup( _
       ByVal assetGroupName As String _
    ) As AssetGroup
    public AssetGroup GetAssetGroup(
       string assetGroupName
    Parameters
    assetGroupName
    Return Value
    The AssetGroup that corresponds to assetGroupName if exists; otherwise, null.
    Exceptions
    ExceptionDescription
    assetGroupName is null or an empty string.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The string comparison used to find the name is case-insensitive.
    Requirements
