ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / EstimatePointCount Method
The area of interest
    Estimates the number of points within the specified area of interest. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function EstimatePointCount( _
       ByVal geometry As Geometry _
    ) As Double
    public double EstimatePointCount(
       Geometry geometry
    Parameters
    geometry
    Exceptions
    ExceptionDescription
    The geometry cannot be null.
    The geometry is of the wrong type.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The geometry must be a ArcGIS.Core.Geometry.Polygon, an ArcGIS.Core.Geometry.Envelope or a ArcGIS.Core.Geometry.GeometryBag containing polygons or envelopes. It will be projected into the spatial reference of the LAS dataset. Z range information, if set on the input geometry, is ignored.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
