Note: For a polygon to be topologically correct, exterior rings should be clockwise and interior rings should be counterclockwise. If there is ever a doubt about the topological correctness of a polygon, call the GeometryEngine.SimplifyAsFeature method to correct any issues.
The boundary of a polygon is the collection of rings by which the polygon is defined. The boundary contains one or more outer rings and zero or more inner rings. An outer ring is oriented clockwise while an inner ring is oriented counter-clockwise. Imagine walking clockwise along an outer ring. The area to your immediate right is the interior of the polygon and to your left is the exterior. Similarly, if you were to walk counter-clockwise along an inner ring, the area to your immediate right is the interior of the polygon and to your left is the exterior.
A Polygon is based upon the parent Geometry class. The Geometry class is immutable which means that you can not change its shape once it is created. If you need to modify a Polygon once it has been created, use the PolygonBuilderEx class instead. The PolygonBuilderEx.ToGeometry method will provide you with the Polygon object.
List<Polygon> internalRings = new List<Polygon>();
// explode the parts of the polygon into a list of individual geometries
// see the "Get the individual parts of a multipart feature"
// snippet for MultipartToSinglePart
var parts = MultipartToSinglePart(polygon); //any polygon
// get an enumeration of clockwise geometries (area > 0) ordered by the area
var clockwiseParts = parts.Where(geom => ((Polygon)geom).Area > 0)
.OrderByDescending(geom => ((Polygon)geom).Area);
// for each of the exterior rings
foreach (var part in clockwiseParts)
// add the first (the largest) ring into the internal collection
if (internalRings.Count == 0)
internalRings.Add(part as Polygon);
// use flag to indicate if current part is within the already selection polygons
bool isWithin = false;
foreach (var item in internalRings)
if (GeometryEngine.Instance.Within(part, item))
isWithin = true;
// if the current polygon is not within any polygon of the internal collection
// then it is disjoint and needs to be added to
if (isWithin == false)
PolygonBuilderEx outerRings = new PolygonBuilderEx();
// now assemble a new polygon geometry based on the internal polygon collection
foreach (var ring in internalRings)
outerRings.AddParts(ring.Parts);
// the final geometry of the outer rings
var outerRingsResult = outerRings.ToGeometry();
// methods need to run on the MCT
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
try
// open a gdb
using (ArcGIS.Core.Data.Geodatabase gdb =
new ArcGIS.Core.Data.Geodatabase(
new FileGeodatabaseConnectionPath(new Uri(@"c:\Temp\MyDatabase.gdb"))))
//Open a featureClass
using (ArcGIS.Core.Data.FeatureClass featureClass =
gdb.OpenDataset<ArcGIS.Core.Data.FeatureClass>("Polygon"))
ArcGIS.Core.Data.QueryFilter filter =
new ArcGIS.Core.Data.QueryFilter()
WhereClause = "OBJECTID = 6"
// get the row
using (ArcGIS.Core.Data.RowCursor rowCursor =
featureClass.Search(filter, false))
while (rowCursor.MoveNext())
using (var row = rowCursor.Current)
long oid = row.GetObjectID();
// get the shape from the row
ArcGIS.Core.Data.Feature feature = row as ArcGIS.Core.Data.Feature;
Polygon polygon = feature.GetShape() as Polygon;
// do something here
catch (Exception ex)
// error - handle appropriately
System.Object
ArcGIS.Core.Geometry.Geometry
ArcGIS.Core.Geometry.Multipart
ArcGIS.Core.Geometry.Polygon
