ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkDefinition Class / GetNetworkSource Method
The name of the NetworkSource to return.
    Gets a NetworkSource object with the specified name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNetworkSource( _
       ByVal networkSourceName As String _
    ) As NetworkSource
    public NetworkSource GetNetworkSource(
       string networkSourceName
    Parameters
    networkSourceName
    Return Value
    The NetworkSource that corresponds to networkSourceName.
    Exceptions
    ExceptionDescription
    networkSourceName is null or an empty string.
    -or-
    There is no NetworkSource that corresponds to networkSourceName.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The string comparison used to find the name is case-insensitive.
    Requirements
