ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkDefinition Class / GetNetworkSources Method
    Gets an IReadOnlyList of the NetworkSource objects used by the network. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNetworkSources() As IReadOnlyList(Of NetworkSource)
    public IReadOnlyList<NetworkSource> GetNetworkSources()
    Return Value
    An IReadOnlyList of the NetworkSource objects used by the network.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
