ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkDefinition Class / GetServiceTerritoryEnvelope Method
    Gets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that has been stored in the ArcGIS.Core.Data.UtilityNetwork. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetServiceTerritoryEnvelope() As Envelope
    public Envelope GetServiceTerritoryEnvelope()
    Return Value
    An ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that has been stored in the ArcGIS.Core.Data.UtilityNetwork.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    This extent is identical to the one returned by UtilityNetwork.GetExtent.
    Requirements
