ArcGIS.Core.Data.Analyst3D Namespace / LasPointFilter Class
Members Example
    Provides a set of parameters to filter for LAS points in LasDataset.SearchPoints.
    Object Model
    LasPointFilter ClassGeometry Class
    Syntax
    Public NotInheritable Class LasPointFilter
    public sealed class LasPointFilter
    Example
    Search LAS Points
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.LasPointFilter pointFilter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
      pointFilter.FilterGeometry = envelope;
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(pointFilter))
        while (ptCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current)
      // search within an extent and limited to specific classification codes
      pointFilter.ClassCodes = new List<int> { 4, 5 };
    Search using pre initialized arrays
      // search all points
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(null))
        int count;
        Coordinate3D[] lasPointsRetrieved = new Coordinate3D[10000];
        while (ptCursor.MoveNextArray(lasPointsRetrieved, null, null, null, out count))
          var pointsLas = lasPointsRetrieved.ToList();
      // use MoveNextArray retrieving coordinates, fileIndex and pointIds
      ArcGIS.Core.Data.Analyst3D.LasPointFilter filter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
      filter.FilterGeometry = envelope;
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(filter))
        int count;
        Coordinate3D[] lasPointsRetrieved = new Coordinate3D[50000];
        int[] fileIndexes = new int[50000];
        double[] pointIds = new double[50000];
        while (ptCursor.MoveNextArray(lasPointsRetrieved, null, fileIndexes, pointIds, out count))
    Search for LAS Points
      // Note: Needs QueuedTask to run
        // searching on the LasDatasetLayer will honor any LasPointDisplayFilter
        using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(null))
            using ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current;
            //Use the point
        using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(pointFilter))
            //Use the point
            //Use the point
    Inheritance Hierarchy
    System.Object
    Requirements
    ArcGIS Pro version: 3.2 or higher.
