ArcGIS.Core.Data.Analyst3D Namespace / LasPointFilter Class / ClassCodes Property
Example
    ClassCodes Property (LasPointFilter)
    Gets and sets the list of class codes to filter. Default value is null.
    Syntax
    public List<int> ClassCodes {get; set;}
    Public Property ClassCodes As List(Of Integer)
    Remarks
    If no list is set, points with any class code will be included.
    Example
    Search LAS Points
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.LasPointFilter pointFilter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
      pointFilter.FilterGeometry = envelope;
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(pointFilter))
        while (ptCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current)
      // search within an extent and limited to specific classification codes
      pointFilter.ClassCodes = new List<int> { 4, 5 };
    Search for LAS Points
      await QueuedTask.Run(() =>
        // searching on the LasDatasetLayer will honor any LasPointDisplayFilter
        // search all points
        using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(null))
            using ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current;
            //Use the point
        using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(pointFilter))
            //Use the point
            //Use the point
    Requirements
    ArcGIS Pro version: 3.2 or higher.
