Public Shadows Function GetDefinition() As TerrainDefinition
public new TerrainDefinition GetDefinition()
Return Value
The TerrainDefinition of this terrain.
string path = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb";
var fileConnection = new FileGeodatabaseConnectionPath(new Uri(path));
//Note: Use QueuedTask.Run to run on the MCT
using (Geodatabase dataStore = new Geodatabase(fileConnection))
string dsName = "nameOfTerrain";
using (var terrainDefinition = dataStore.GetDefinition<ArcGIS.Core.Data.Analyst3D.TerrainDefinition>(dsName))
// get the feature class names that are used in the terrain
var fcNames = terrainDefinition.GetFeatureClassNames();
//Note: Needs QueuedTask to run
using (var tin = tinLayer.GetTinDataset())
using var tinDef = tin.GetDefinition();
Envelope extent = tinDef.GetExtent();
SpatialReference sr = tinDef.GetSpatialReference();
using (terrain = terrainLayer.GetTerrain())
using var terrainDef = terrain.GetDefinition();
Envelope extent = terrainDef.GetExtent();
SpatialReference sr = terrainDef.GetSpatialReference();
using (lasDataset = lasDatasetLayer.GetLasDataset())
using var lasDatasetDef = lasDataset.GetDefinition();
Envelope extent = lasDatasetDef.GetExtent();
SpatialReference sr = lasDatasetDef.GetSpatialReference();
