// This routine creates an Add function to sum the Load network attribute during a trace
static void ApplyFunction(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
// Get a NetworkAttribute object for the Load network attribute from the UtilityNetworkDefinition
using NetworkAttribute loadNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Load");
// Create a function to sum the Load
Add sumLoadFunction = new Add(loadNetworkAttribute);
// Add this function to our trace configuration
traceConfiguration.Functions = new List<Function>() { sumLoadFunction };
// This routine creates a FunctionBarrier that stops traversal when the total shape length exceeds 1000 feet
static void CreateFunctionBarrier(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
// Create a NetworkAttribute object for the Shape length network attribute from the UtilityNetworkDefinition
using NetworkAttribute shapeLengthNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Shape length");
// Create a function that adds up shape length
Add lengthFunction = new Add(shapeLengthNetworkAttribute);
// Create a function barrier that stops traversal after 1000 feet
FunctionBarrier distanceBarrier = new FunctionBarrier(lengthFunction, Operator.GreaterThan, 1000.0);
// Set this function barrier
traceConfiguration.Traversability.FunctionBarriers = new List<FunctionBarrier>() { distanceBarrier };
System.Object
ArcGIS.Core.Data.UtilityNetwork.Trace.Function
ArcGIS.Core.Data.UtilityNetwork.Trace.Add
ArcGIS.Core.Data.UtilityNetwork.Trace.Average
ArcGIS.Core.Data.UtilityNetwork.Trace.Count
ArcGIS.Core.Data.UtilityNetwork.Trace.Max
ArcGIS.Core.Data.UtilityNetwork.Trace.Min
ArcGIS.Core.Data.UtilityNetwork.Trace.Subtract
