ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / FunctionBarrier Class / FunctionBarrier Constructor
The Function that is used to calculate a value.
The Operator that is used to perform the comparison (equals, less than etc.).
The value that the functional expression is compared against.
Example
    Initializes a new instance of the FunctionBarrier class.
    Syntax
    Public Function New( _
       ByVal function As Function, _
       ByVal comparisonOperator As Operator, _
       ByVal value As Double _
    Parameters
    function
    comparisonOperator
    value
    Example
    Create a FunctionBarrier
      // This routine creates a FunctionBarrier that stops traversal when the total shape length exceeds 1000 feet
      static void CreateFunctionBarrier(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
        // Create a NetworkAttribute object for the Shape length network attribute from the UtilityNetworkDefinition
        using NetworkAttribute shapeLengthNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Shape length");
        // Create a function that adds up shape length
        Add lengthFunction = new Add(shapeLengthNetworkAttribute);
        // Create a function barrier that stops traversal after 1000 feet
        FunctionBarrier distanceBarrier = new FunctionBarrier(lengthFunction, Operator.GreaterThan, 1000.0);
        // Set this function barrier
        traceConfiguration.Traversability.FunctionBarriers = new List<FunctionBarrier>() { distanceBarrier };
    Requirements
