ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / TraceArgument Class / Configuration Property
Example
    Configuration Property (TraceArgument)
    Additional tracing configuration parameters
    Syntax
    public TraceConfiguration Configuration {get; set;}
    Public Property Configuration As TraceConfiguration
    Example
    Create a Trace Argument
      // This routine creates a TraceArgument object and assigns a TraceConfiguration to it
      static void CreateTraceArgument()
        IReadOnlyList<Element> startingPointList = new List<Element>();
        // Code to fill in list of starting points goes here...
        TraceArgument traceArgument = new TraceArgument(startingPointList);
        TraceConfiguration traceConfiguration = new TraceConfiguration();
        // Code to fill in trace configuration goes here...
        traceArgument.Configuration = traceConfiguration;
    Trace a utility network with the digitized direction
      // This routine demonstrates how to perform a trace using the digitized direction of features
      static void TraceWithDigitizedDirection(UtilityNetwork utilityNetwork, Element startElement)
        using TraceManager traceManager = utilityNetwork.GetTraceManager();
        // Trace configuration with digitized direction
          IncludeIsolatedFeatures = true,
          IncludeBarriersWithResults = true,
          UseDigitizedDirection = true
        // Trace argument
        List<Element> startElements = new List<Element> { startElement };
        TraceArgument traceArgument = new TraceArgument(startElements);
        // Results
        DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
        IReadOnlyList<Result> traceResults = downstreamTracer.Trace(traceArgument);
        foreach (Result traceResult in traceResults)
          // Iterate trace results
    Export a utility network trace as a JSON file
      // This routine demonstrates how to perform a trace and export the results as a JSON file
      static void ExportUtilityNetworkTraceAsJSON(UtilityNetwork utilityNetwork)
        using (TraceManager traceManager = utilityNetwork.GetTraceManager())
        using (UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition())
        using (NetworkSource deviceNetworkSource = GetNetworkSource(utilityNetworkDefinition, "GasDevice") as NetworkSource)
        using (FeatureClass distributionDeviceFeatureClass = utilityNetwork.GetTable(deviceNetworkSource) as FeatureClass)
        using (FeatureClassDefinition distributionDeviceDefinition = distributionDeviceFeatureClass.GetDefinition())
        using (AssetGroup deviceAssetGroup = deviceNetworkSource.GetAssetGroup("Regulator"))
        using (AssetType deviceAssetType = deviceAssetGroup.GetAssetType("Pressure Reducing"))
        using (NetworkAttribute deviceStatusNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("DeviceStatus"))
        using (NetworkAttribute accessibleNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Accessible"))
          // Domain and tier information
          DomainNetwork domainNetwork = utilityNetworkDefinition.GetDomainNetwork("Gas");
          Tier pipeDistributionSystemTier = domainNetwork.GetTier("Pipe Distribution");
          // Start elements
          Element startingPoint1 = utilityNetwork.CreateElement(deviceAssetType, Guid.Parse("{28CF437E-950C-41B7-B839-8BC45570DE40}"));
          Element startingPoint2 = utilityNetwork.CreateElement(deviceAssetType, Guid.Parse("{63C22828-7BC9-49ED-A14A-A596559B6CB3}"));
          startingPoint1.Terminal = startingPoint1.AssetType.GetTerminalConfiguration().Terminals
            .First(x => x.IsUpstreamTerminal);
          startingPoint2.Terminal = startingPoint2.AssetType.GetTerminalConfiguration().Terminals
          List<Element> startingPoints = [startingPoint1, startingPoint2];
          List<Element> barriers = [];
          // Set up trace filter: DeviceStatus = Open (1) AND Accessible = 1
          NetworkAttributeComparison statusNetworkAttributeComparison = new NetworkAttributeComparison(deviceStatusNetworkAttribute, Operator.Equal, 1);
          NetworkAttributeComparison networkAttributeComparison = new NetworkAttributeComparison(accessibleNetworkAttribute, Operator.Equal, 1);
          // Set trace configuration
            AllowIndeterminateFlow = true,
            IgnoreBarriersAtStartingPoints = false,
            IncludeContainers = true,
            IncludeContent = true,
            IncludeIsolatedFeatures = false,
            IncludeUpToFirstSpatialContainer = false
          traceConfiguration.Filter.Barriers = new And(statusNetworkAttributeComparison, networkAttributeComparison);
          traceConfiguration.DomainNetwork = domainNetwork;
          traceConfiguration.SourceTier = pipeDistributionSystemTier;
          // Attribute fields of a network source
          List<string> deviceFields = distributionDeviceDefinition.GetFields().Select(f => f.Name).ToList();
          // Network attributes
          List<string> networkattributeNames = new List<string>();
          IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
          foreach (NetworkAttribute networkAttribute in networkAttributes)
            networkattributeNames.Add(networkAttribute.Name);
          // Result Types
          List<ResultType> resultTypeList = new List<ResultType>() { ResultType.Feature };
          // Resutl Options
          ResultOptions resultOptions = new ResultOptions()
            IncludeGeometry = true,
            NetworkAttributes = networkattributeNames,
            ResultFields = new Dictionary<NetworkSource, List<string>>() { { deviceNetworkSource, deviceFields } }
          // Trace Arguments
          TraceArgument traceArgument = new TraceArgument(startingPoints)
            Barriers = barriers,
            Configuration = traceConfiguration,
            ResultTypes = resultTypeList,
            ResultOptions = resultOptions
          ConnectedTracer connectedTracer = traceManager.GetTracer<ConnectedTracer>();
          // Set export options
          TraceExportOptions exportOptions = new TraceExportOptions()
            ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
            IncludeDomainDescriptions = true,
          // Path to export JSON
          string jsonPath = $"{Path.GetTempPath()}TraceResults.json";
          Uri jsonUri = new Uri(jsonPath);
          // Export
          connectedTracer.Export(jsonUri, traceArgument, exportOptions);
          string jsonAbsolutePath = HttpUtility.UrlDecode(jsonUri.AbsolutePath);
          if (jsonUri.IsFile && File.Exists(jsonAbsolutePath))
            // Work with the JSON results
        NetworkSource GetNetworkSource(UtilityNetworkDefinition unDefinition, string name)
          IReadOnlyList<NetworkSource> allSources = unDefinition.GetNetworkSources();
          foreach (NetworkSource source in allSources)
            if (name.Contains("Partitioned Sink"))
              if (source.Name.Replace(" ", "").ToUpper().Contains(name.Replace(" ", "").ToUpper()) ||
                    .Contains(name.Replace("Partitioned Sink", "Part_Sink").Replace(" ", "").ToUpper()))
                return source;
            if (name.Contains("Hierarchical Sink"))
                    .Contains(name.Replace("Hierarchical Sink", "Hier_Sink").Replace(" ", "").ToUpper()))
                return source;
            if (source.Name.Replace(" ", "").ToUpper().Contains(name.Replace(" ", "").ToUpper()))
              return source;
          return null;
    Fetch features and network attributes from a utility network during trace
      // This routine demonstrates how to fetch features and network attributes from a utility network during a trace
      static void FetchFeaturesAndAttributes(UtilityNetwork utilityNetwork)
        using (Geodatabase geodatabase = utilityNetwork.GetDatastore() as Geodatabase)
        using (RelationshipClass valveInspectionRelationshipClass = geodatabase.OpenDataset<RelationshipClass>("GasDeviceToValveInspection"))
        using (Table valveInspection = geodatabase.OpenDataset<Table>("ValveInspection"))
        using (TableDefinition valveInspectionDefn = valveInspection.GetDefinition())
          // Start elements
          List<Element> startingPoints = new List<Element>() { startingPoint1, startingPoint2 };
          List<Element> barriers = new List<Element>();
          // Get the field names for the related records table (ValveInspection)
          IReadOnlyList<Field> valveRelatedRecords = valveInspectionDefn.GetFields();
          List<string> valveFieldNames = valveRelatedRecords.Select(f => f.Name).ToList();
          // Result Types
          List<ResultType> resultTypeList = new List<ResultType>() { ResultType.Feature, ResultType.RelatedRecord };
          // Resutl Options
            ResultFields = new Dictionary<NetworkSource, List<string>>() { { deviceNetworkSource, deviceFields } },
            RelatedRecordFields = new Dictionary<RelationshipClass, List<string>>() { { valveInspectionRelationshipClass, valveFieldNames } }
          // Trace Arguments
          // Tracer
          // Async trace result
            connectedTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous);
            if (traceResult is FeatureElementResult featureElementResult)
              IReadOnlyList<FeatureElement> featureElements = featureElementResult.FeatureElements;
              // Iterate through the feature elements
              foreach (FeatureElement featureElement in featureElements)
                // Get the field values specified in the `ResultOptions`
                IReadOnlyList<TraceResultFieldValue> resultFieldValues = featureElement.ResultFieldValues;
                foreach (TraceResultFieldValue fieldValue in resultFieldValues)
                  if (fieldValue.FieldType == FieldType.Geometry)
                    // Get the geometry of the feature
                    Geometry geometry = fieldValue.Value as Geometry;
                // Get the Network attribute values specified in the `ResultOptions`
                IReadOnlyList<TraceResultFieldValue> networkAttributeValues = featureElement.ResultNetworkAttributeValues;
            if (traceResult is RelatedRecordResult relatedRecordResult)
              IReadOnlyList<RelatedRecord> relatedRecords = relatedRecordResult.RelatedRecords;
              // Iterate through the related records
              foreach (RelatedRecord relatedRecord in relatedRecords)
                IReadOnlyList<RelationshipClassValue> relationshipClassValues = relatedRecord.RelationshipClassValues;
                foreach (RelationshipClassValue relationshipClassValue in relationshipClassValues)
                  // Access the IDs and name associated with this relationship class
                  var destinationId = relationshipClassValue.DestinationID;
                  var name = relationshipClassValue.Name;
                  var originId = relationshipClassValue.OriginID;
                  // Access the relationship values associated with this relationship class
                  IReadOnlyList<RelationshipValue> relationshipValues = relationshipClassValue.RelationshipValues;
                  foreach (RelationshipValue relationshipValue in relationshipValues)
                    // Geometry associated with this relationship value
                    Geometry geometry = relationshipValue.Geometry;
                    // Out fields associated with non attributed relationship class
                    IReadOnlyList<TraceResultFieldValue> outFields = relationshipValue.OutFields;
                    // Out fields associated with attributed relationship class
                    // IReadOnlyList<TraceResultFieldValue> relationshipOutFields = relationshipValue.RelationshipOutFields;
        // Helper inline function
                return source;
                return source;
              return source;
          return null;
    Run a path trace in the telecom domain network
    await QueuedTask.Run(() =>
      using (NetworkSource deviceNetworkSource = telecomDomainNetwork.NetworkSources.First(f => f.Name.Contains("TelecomDevice")))
      using (AssetGroup assetGroup = deviceNetworkSource.GetAssetGroup("Port"))
      using (AssetType assetType = assetGroup.GetAssetType("Port"))
        Guid startGuid = new Guid("4BB4560A-34F3-4BBA-93D5-C5D6B26F2709");
        Guid stopGuid = new Guid("32203C76-E484-473A-AEA5-B1AB92A0C198");
        TelecomElement startElement = utilityNetwork.CreateElement(assetType, startGuid) as TelecomElement;
        TelecomElement stopElement = utilityNetwork.CreateElement(assetType, stopGuid) as TelecomElement;
        List<TelecomElement> startingLocations = new List<TelecomElement>() { startElement };
        List<TelecomElement> stoppingLocations = new List<TelecomElement>() { stopElement };
        // Path trace configuration
          MaxHops = 100,
          NumPaths = 2,
          DomainNetwork = telecomDomainNetwork,
          ValidateConsistency = true
        // Trace argument for the path trace with the starting and stopping locations
        TraceArgument traceArgument = new TraceArgument(startingLocations)
          StoppingLocations = stoppingLocations,
          ResultTypes = new List<ResultType>() { ResultType.Path },
          ResultOptions = new ResultOptions { IncludeGeometry = true }
        // Run the path trace asynchronously
        PathTracer pathTracer = traceManager.GetTracer<PathTracer>();
        IReadOnlyList<Result> results = pathTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous);
        // Iterate through the path trace results
        foreach (Result result in results)
          if (result is PathResult pathResult)
            IReadOnlyList<TracePath> paths = pathResult.Paths;
            foreach (TracePath path in paths)
              Element startLocation = path.StartLocation;
              Element stopLocation = path.StopLocation;
              Geometry pathGeometry = path.Geometry;
              IReadOnlyList<PathConnectivity> pathConnectivities = path.PathConnectivities;
              foreach (PathConnectivity pathConnectivity in pathConnectivities)
                Console.WriteLine($"Edge: {pathConnectivity.Edge.GlobalID}, Junction: {pathConnectivity.Junction.GlobalID}");
          else
            Console.WriteLine("Unexpected result type.");
    Run a circuit trace in the telecom domain network with a wavelength propagator
      using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
        Circuit circuitToTrace = circuitManager.GetCircuits(new CircuitFilter(circuitNames)).FirstOrDefault();
        // Get wavelength network attribute
        NetworkAttribute wavelengthAttribute = utilityNetworkDefinition.GetNetworkAttribute("Wavelength");
        // Propagator for the wavelength attribute that uses the CWDM wavelength scheme ( C27 = 1270nm)
        Propagator propagator = new Propagator(wavelengthAttribute, PropagatorFunction.BitwiseAnd, Operator.IncludesAny, "C27");
        // Trace configuration for the circuit trace with the wavelength propagator
          MaxHops = 10,
          NumPaths = 5,
          InferConnectivity = true,
          Propagators = new List<Propagator>() { propagator }
        // Trace argument for the circuit trace with the trace configuration
        TraceArgument traceArgument = new TraceArgument(circuitToTrace)
          ResultTypes = new List<ResultType> { ResultType.Circuit },
          ResultOptions = new ResultOptions() { IncludeGeometry = true }
        // Execute the circuit trace
        CircuitTracer circuitTracer = traceManager.GetTracer<CircuitTracer>();
        IReadOnlyList<Result> results = circuitTracer.Trace(traceArgument);
        // Iterate through the circuit trace results
          if (result is CircuitResult circuitResult)
            IReadOnlyList<CircuitPath> circuitPaths = circuitResult.CircuitPaths;
            foreach (CircuitPath circuitPath in circuitPaths)
              Circuit circuit = circuitPath.Circuit;
              TracePath path = circuitPath.Path;
              Geometry geometry = circuitPath.Geometry;
              IReadOnlyDictionary<int, TracePath> sectionPaths = circuitPath.SectionPaths;
              foreach (KeyValuePair<int, TracePath> sectionPath in sectionPaths)
                int sectionID = sectionPath.Key;
                TracePath sectionGeometry = sectionPath.Value;
                Console.WriteLine($"Section ID: {sectionID}, Section Geometry: {sectionGeometry.Geometry.ToJson()}");
          else
    Requirements
