ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / TraceConfiguration Class / SourceTier Property
    SourceTier Property
    The ArcGIS.Core.Data.UtilityNetwork.Tier that is used as the start of the trace.
    Syntax
    Public Property SourceTier As Tier
    public Tier SourceTier {get; set;}
    Remarks
    This property is only used with subnetwork-based traces (SubnetworkTracer, UpstreamTracer, etc.). If DomainNetwork represents a ArcGIS.Core.Data.UtilityNetwork.TierDefinition.Partitioned network, this property is optional. If not null, the Trace routines will perform an additional check to validate that the starting points and barriers belong to this tier. If DomainNetwork represents a ArcGIS.Core.Data.UtilityNetwork.TierDefinition.Hierarchical network, this property is required. Since rows in hierarchical networks can belong to multiple tiers, this property tells the subnetwork tracer which tier to use for tracing.
    Requirements
