Public Function Transform2D( _ ByVal inCoordinates() As Coordinate2D, _ ByVal projectionTransformation As ProjectionTransformation, _ ByRef outCoordinates() As Coordinate2D, _ Optional ByVal removeClippedCoordinates As Boolean _ ) As Integer
public int Transform2D( Coordinate2D[] inCoordinates, ProjectionTransformation projectionTransformation, ref Coordinate2D[] outCoordinates, bool removeClippedCoordinates )
Parameters
- inCoordinates
- The set of coordinates to be transformed.
- projectionTransformation
- The projection transformation specifying the input and output spatial references and possibly the geographic transformations to use for the transformation.
- outCoordinates
- The set of transformed coordinates. If it is null or the length is less than the length of inCoordinates, then a new array will be allocated.
- removeClippedCoordinates
- (Optional) The boolean value specifying whether to remove clipped coordinates or not. If true, the coordinates outside of the horizon will be removed from the output, and the number of initialized elements in the output is the number of coordinates transformed which may be less than the number of elements in inCoordinates. If false, all coordinates are preserved, the clipped out coordinates are set to NaN in the output, and the number of elements in the output is equal to the number of elements in inCoordinates. The default value is true.
Return Value
The number of transformed coordinates.
