ArcGIS.Desktop.Core.Portal Namespace / PortalItem Class / GetItemDataAsync Method
Example
    Gets the item data. This resource is available only for the file and text item types.
    Syntax
    public Task<bool> GetItemDataAsync(
       string fileName
    Public Function GetItemDataAsync( _
       ByVal fileName As String _
    ) As Task(Of Boolean)
    Parameters
    fileName
    Remarks
    The data component of an item (the "item file") is used to stream the actual data represented by the item to the client.
    Example
    Portal: Download any package items in the user content
      var packages = new List<PortalItemType>
        PortalItemType.BasemapPackage,
        PortalItemType.GeoprocessingPackage,
        PortalItemType.LayerPackage,
        PortalItemType.LocatorPackage,
        PortalItemType.MapPackage,
        PortalItemType.ProjectPackage,
        PortalItemType.ScenePackage,
        PortalItemType.RulePackage,
        PortalItemType.VectorTilePackage
      var folder = @"E:\Temp\PortalAPITest\";
      //Get the UserContent - refer to the initialization section above for more details
      foreach (var di in userContent.PortalItems.Where(pi => packages.Contains(pi.PortalItemType)))
        var path = System.IO.Path.Combine(folder, di.Name);
        await di.GetItemDataAsync(path);
    Requirements
