public PortalItemType PortalItemType {get;}
Public ReadOnly Property PortalItemType As PortalItemType
var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(@"https://<serverName>.<domain>.com/portal/", UriKind.Absolute));
string owner = string.Empty;
//Get the signed on user name
owner = await QueuedTask.Run(() => projectPortal.GetSignOnUsername());
//Get the user content from the portal
PortalUserContent userContent = await projectPortal.GetUserContentAsync(owner);
//Get the first portal project item
var firstPortalProject = userContent.PortalItems.FirstOrDefault(pi => pi.PortalItemType == PortalItemType.ProProject);
var portalProjectUri = firstPortalProject.ItemUri.ToString();
//Check if project can be opened
string docVer = string.Empty;
if (Project.CanOpen(portalProjectUri, out docVer))
Project.OpenAsync(portalProjectUri);
//Note: If Project.CanOpen returns false, the project cannot be opened. One reason could be
// the active portal is not the same as the portal of the project. Refer to the snippet: [Workflow to open an ArcGIS Pro project](ProSnippets-sharing#workflow-to-open-an-arcgis-pro-project)
var packages = new List<PortalItemType>
PortalItemType.BasemapPackage,
PortalItemType.GeoprocessingPackage,
PortalItemType.LayerPackage,
PortalItemType.LocatorPackage,
PortalItemType.MapPackage,
PortalItemType.ProjectPackage,
PortalItemType.ScenePackage,
PortalItemType.RulePackage,
PortalItemType.VectorTilePackage
var folder = @"E:\Temp\PortalAPITest\";
//Get the UserContent - refer to the initialization section above for more details
foreach (var di in userContent.PortalItems.Where(pi => packages.Contains(pi.PortalItemType)))
var path = System.IO.Path.Combine(folder, di.Name);
await di.GetItemDataAsync(path);
